I have printer x3470 and after changing to new cartridge a notice comes up on the screen"cover open" and printer will not function. can you suggest solution?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Have closed cover properly. cover vup sign still there.
Try to follow the steps below to identify and fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Open the printer cover and remove the cartridges.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  5. When the printer turns on and comes back with the error on the display screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new cartridge.
  9. If no error appears, try to print again to verify that the problem is fixed.
Oct 12, 2011 | Lexmark X3470 All-In-One InkJet Printer
I changed the ink cartridge and now the printer screen reads "cover open"
Sometiems you have to close the covers firmly to get the sensor to recognize that it is actually shut
Jun 16, 2010 | Lexmark X3470 All-In-One InkJet Printer
My printer says "Cover Open" after changing the cartridge. Nothing was broken. HOW DO I FIX IT?!?!?!
The cover has been probably opened too widely and the the lever on the cover open sensor is knocked off the switch assembly. If you teer off the cover, you will see a little plastic lid on the right (where electric cables and switches are) This switch has come out its switch. With some fiddling around you should be able to put it back in place.
Feb 06, 2010 | Lexmark X3470 All-In-One InkJet Printer
Says cover open but its not
Open the cover, remove the ink cartridges, reinstert them, close the cover, and power it back on.
Apr 21, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open message error
HI this will help you, I have located the link and this is going to give you all the info that you need.
Please do not forget to rate our chat session ok
www.fixyourownprinter.com/forums/printer/46998
Thank You
Jayson
Sep 21, 2008 | Lexmark X3470 All-In-One InkJet Printer
LEXMARK 3470 COVER OPEN
there is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Sep 17, 2008 | Lexmark X3470 All-In-One InkJet Printer
Please do not forget to rate my solution
Thank You
Jayson
Sep 09, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Aug 12, 2008 | Lexmark X3470 All-In-One InkJet Printer
X3470
my printer keeps saying cover opened and won't swcith off or nothing can u please help me
Jul 03, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open
see your printer cover for broken.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
26 people viewed this question
jasbo
jasbo
