Question about Toshiba 50H81 50" Rear Projection Television
Toshiba 50H12 convergence
Problem with convergence - can not get it to line up tried both the auto and manual ways. The bottom line is also bowed.
I believe the IC's need to be replaced.
Do you have part numbers?
My husband should have no problem with soldering them.
Thank you.
  • john_10 Feb 07, 2009
    I have a similar problem. Red convergence was off ~ 2" horizontally.
    Could adjust it vertically, but not horizontally. Changed the convergence IC's. Now I have power, but no picture/sound. Does
    anyone have a manual for Toshiba 50H12? Any hints on what I did wrong?
    thanks
    John.reguera@yahoo.com
  • 133 Answers
Your convergence IC's are bad, it is 2 3 inch chips that have to be soldered onto a board in the back, after you unsolder the old ones,they cost about 40 $ for both
Posted on Jan 08, 2009
My Toshiba projection screen TV the picture is bowed and the colors don't line up
3d colors not lining up poblem dicates "convergence issues.. bowing piture may indicate complete faliure of convergence alignment cuircits... depending on model the most likely cause will be 2 micochips (ic's called stk<s)
Aug 23, 2010 | Toshiba Televison & Video
RCA hd52w67 analog convergence problem.
with Tv off press and hold ch- and vol- at same time untill tv turns on then release and you should be in factory settings service mode.
May 26, 2010 | Televison & Video
Toshiba 57hx81 tv has a bow at bottom of screen and blue in color tried using toush focus & got error then tried to focus manually & couldn't get the bottom lines to focus all the way down
noted in the owners manual, if auto focus returns message "error" , it suggests to use manual convergence setting..failing that, is it resonable to suspect that the STK-392-110 (convergence (2)chips)are beginning to fail, bendt horizonital lines is the effect. you can check all the resistors and pico fuses (power board)near the chips for shorts, chances are they are ok. seeing that there is somewhat of a picture (kinda like 3-d). i would repaired it!.. while your there do the hyperboard repair as well by replacing the 10 caps with 16v@10uf. (causing a wavy vertical distortion effect).
Jan 12, 2010 | Toshiba 57HX81 57" Rear Projection...
The screen on my toshiba 50h12 is messed up. its as though the horizontal is not matching up...how can i fix this myself?
It sounds convergence out chips got bad in your Tv and causing problem. Replace convergence out ICs in TV if you are familiar with electronic stuff repair.
Required parts are available in Part Store.
Dec 24, 2009 | Toshiba 50H81 50" Rear Projection...
Blue color is off and bowed at bottom
Needs the 2 convergence amplifiers replaced and then convergence alignment carried out(Could be pricy)
Dec 04, 2009 | Toshiba 50H81 50" Rear Projection...
TOSHIBA projection television Model 50H12
Good Day, klynn69;
Even though you did not ask a question, I assume you want to know what's wrong. It sounds like the TV has experienced a Convergence Circuit Failure. If you are really handy replace Conv output Amp IC's AND make sure all pico fuses are ok, all jumpers have secure connections OR call for service to An Authorized Service Center and have them come out and give an estimate B4 repair. AVG cost $550.00. Good Luck, big IRISH.
Sep 07, 2008 | Toshiba Televison & Video
Toshiba 40who8b convergeance problem
Good Day, harri1234;
Sounds like a convergence problem.
Convergence Output IC Failure
Corrective Action: Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version.
Good Luck, Big Irish.
Jun 23, 2008 | Toshiba 42H81 42" Rear Projection...
Red bow on top and bottom of 61dx01b
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 21, 2008 | Samsung PCL5415RB 54" Rear Projection...
Multiple images on right side of screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergance amp ic bad
Dec 23, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
324 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
