Question about Lexmark X2650 All-In-One InkJet Printer
Error on newly installed printer.
My new printer which i have just installed keeps flashing EC1. Not sure what to do as it appeared to install properly. It is a Lexmark X2650
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
Canon mp830 error code 6502
Hi Dee,
The error code 6502 indicates an ink tank position sensor error.There's no communication between the printer and the newly installed cartridges.To clear this,you have to remove the cartridges,check the plastic tape usually around them when new and make sure you COMPLETELY remove this tape.Ensure nothing is covering the chip or LED on the rear of the print cartridge.Also gently wipe out any appearing smudges.
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Printer flashes ec1 and has a new cartridge
Please make sure that you are inserting the correct cartridge version for your model. The Lexmark X2600 printer uses 14/15 cartrdge.
The EC1 error indicates that the printhead ID is not valid. Please follow the steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Oct 24, 2011 | Lexmark X2600 InkJet Printer
My printer flashes ec1 and has new cartridge in it
My Lexmark printer shows EC1 on it, what does that mean and what do I do ?
The EC1 error code means "Incorrect Printhead". Try to follow the steps below to identify and fix the issue:
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
Aug 31, 2011 | Lexmark X2600 InkJet Printer
I have a lexmark x2695 and when I turn on the printer appear a flashing error "1 E C"
The EC1 error code indicates that the printhead ID is not valid. Open the printer cover and remove both your cartridges. Close the cover. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert one cartridge first and close the cover. Check for any errors. If no error appears, reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You may also try to insert a different known working cartridge to determine if the other is faulty.
May 12, 2011 | Lexmark X2600 InkJet Printer
Lexmark x422
900 RIP errors are errors in the Engine Code. There is an EC1 file available at: http://support.lexmark.com/perl/support/support.cgi.
Download and install the file by following the link on the above page, first error discription.
Don
Mar 08, 2009 | Lexmark X422 All-In-One Laser Printer
Hi, i have a lexmark x2690 and am trying to install but get an error message and it won't print at all ... not even at test page... it flashes ec1 and the cartridge light flashes but they are both...
Did you take the tape off of the print cartridge before you put them in? Did you install the software first then when prompted turn the printer on then plug in the printer (usb) cord to the computer? Did you go into the print control panel and activate the print cartridges that you put in there? Sometimes you have to tell the printer that you installed new print cartridges.
Jun 30, 2008 | Computers & Internet
Printer won't process new catridges. These cartridges have been refilled.
Did you install the original cartridge? if you have the old empty cartridge, try to install it and check the error is empty cartridge..if so the problem is the newly installed cartridge. try to buy the new original one.
Dec 17, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Lexmark X2650 All-In-One InkJet Printer Logo
799 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
