Question about Toshiba COPIERS E-STUDIO 520 Copier
I AM PRINTING A DOCUMENT 2 SIDED AND I NEED IT TO FOLD IN HALF??
Running a Toshiba studio 520, need to fold document in half as I print, please advise.
Thank You! Kathy
    Problem Solver:
  • 10 Answers
You could only do it if you have a saddle stich finisher..and if you do.. on the screen tap on finishing and follow step by step you will find saddle stich tap on it .. remember you could only do it with 8 1/2 X 14 (legal) and 11 X 17 (ledger)
Posted on Jul 15, 2009
Printmaster half-fold printing on epson printer
Before printing you need to select the size and orientation and it's a good idea to look at the preview before printing. That saves a lot of paper.
Nov 19, 2017 | Epson Office Equipment & Supplies
Need help to print brochures
You can take help from a brochure printing company that would provide you best attractive designed brochures for your business or service.
I can suggest you best template collection that you can use as a base template or for inspiration.
Brochure Templates PSD would provide you a wide range of templates which is designed carefully with best fonts, colors, and layouts.
Mar 12, 2012 | Office Equipment & Supplies
STARTS PRINTING AND PAPER GETS STUCK HALF WAY THROUGH. THE PRINTER IS ONLY 3MONTH OLD, HOW DO I FIX THIS.
I need to know where the paper gets stuck and does it concertina ( fold up ).
Where is the leading edge of the paper when the paper stops feeding?
Jun 13, 2011 | Lexmark E260dn Laser Printer
How can I print booklets?
One sheet booklets generally are two-sided printing jobs, accordion fold, gate fold or quarter or half fold styles. Determine which of these styles your's will be and make a "dummy"....it's as simple as folding the paper according to its finished form and marking each of the panels with scaled type or pictures. By making the dummy, the layout will reveal itself when opened and flattened. You will most likely have to "flip" the pages and print each side at separate times unless your machine is a "duplex" type of printer. The "dummy" is the key to the puzzle. Simple as folding and unfolding the panels.
Jan 30, 2011 | Canon LASER SHOT LBP-2900 Printer
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
Konica minolta 600 has problem printing duplex mailmerge and tir
CAUSE: The tri-fold printed on side is set incorrectly on the machine.
SOLUTION: To change the tri-fold from printing inside fold to printing outside fold, perform the following:
1. Press the Utility key.
2. Select Admin mode and enter the password.
3. Press Copier Setting.
4. Press the down arrow.
5. Press Tri-Fold Printed on Side Selection.
6. Press either INSIDE or OUTSIDE.
good lock
Feb 28, 2009 | Panasonic DP-C264 Copier
When printing document, half prints.
You didn't mention which paper feed you are using but I would guess tractor-feed Z-fold? If so, you may have a damaged sprocket drive.
If not, you need to remove the platen and check for paper scraps in the paper path and if you ever use the printer with labels, you may have some residue from the adhesive impeding paper movement.
Also check that you do not have the printhead positioned too close to the paper as this can cause drag that will cause paper to slip.
These printers are just about bullet-proof with very little maintenance.
Feb 06, 2009 | Epson LQ-590 Matrix Printer
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Dec 25, 2008 | Computers & Internet
Printing booklets in Word 2007!!
Under file > print set up select two sided it will print bot the sided
Sep 09, 2008 | Microsoft Office Professional 2007 Full...
71 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
