Question about Minolta Di351 All-In-One Laser Printer
Minolta 251f di
How can i get tx report always when i sent fax
  • Minolta Master
  • 6,359 Answers
Go to admin. Password, defaullt 00000000 then admin managenmt reports
Posted on Dec 26, 2015
SOURCE: Repeated Fax TX report printing
Canon tech support walked me through this. Turn unit off. Unplug for 30 sec. Plug in, turn on. Memory should be cleared.
Posted on Mar 03, 2008
SOURCE: MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Posted on Apr 25, 2008
chibibarako
  • 7 Answers
SOURCE: minolta di 151
You're going to have a tough time finding a paper manual, since Minolta was bought out by Konica. However, if you have Adobe or another PDF reader you can get the manual on the Konica-Minolta website: DI151 Fax Manual
Posted on Oct 24, 2008
SOURCE: canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Posted on Jun 14, 2009
SOURCE: Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Posted on Jul 30, 2009
The imaging unit needs to be changed
Buy new imaging unit, part #4163-612
then follow instructions here: http://www.manualslib.com/manual/611548/Konica-Minolta-Di-200.html?page=56#manual
Mar 11, 2015 | Konica Minolta Dialta Di200, 200f, 250,...
Fax confirmation
Go to Admin Management Default pw 12345678 or 0000000 then to Admin 1, Then to Report settings TX Report 3 options on always for every fax out, off, and only if problem with fax.
Oct 10, 2014 | Minolta bizhub 200 All-In-One Printer
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
How do i get a report to print to let me know what faxes were sent and when
1) Set the original on the feed device or the glass
2) Press the (Fax/Scan) key.
3) Press (Fax Menu)
4) Press (Set 1), then press (TX Report)
5) Press ON
6) Press (ENTER) and put in the Fax number
7) After the fax went through, you will receive the confirmation
8) Once transmission is performed, it returnes to (Default), which means, when you send another fax, there will be no Transmission Report unless you go through the whole procedure again.
Jun 30, 2010 | Minolta DI-2010F Copier
A report for sent faxes
Look on page 31 to set Fax Call Report Time, set it to "send fax only" for Tx confirmation report.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bpl11457/bpl11457.pdf
Sep 23, 2009 | HP LaserJet 3330 All-In-One Printer
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Aug 10, 2009 | Minolta bizhub 200 Copier
TX Report misses out Destination Number
The ID on the TX report only show the ID if the ID is programed on the fax machine you send it to.The only way is to ask the destinated party to program the Fax name.
Apr 30, 2009 | Canon FAX-JX200
Turn off confirmation page
log into the web administration page as administrator
choose fax/scan tab
report settings
Tx Report
choose turn on/off/if tx fail
I chose both single and multiple destinations
if tx fails
Tested scan to email and fax to bad addresses and page printed as confirmation of failure
No pages printed for successful Tx
Note - you can still manually request confirmation at printer menu
Fax/scan
fax menu
tx report
on
enter
start fax or scan to email
Nov 05, 2008 | Minolta bizhub 200 All-In-One Printer
Konica Minolta C250 Scanner problem
To print the transmission report:
1. Press the [Fax/Scan] key to display the Fax mode screen.
2. Touch [FAX Menu].
3. Touch [TX Report] on the Set 1 tab.
4. Select how to output the report, and then touch [Enter].
– Default: The transmission report is printed according to the previously specified method.
– ON: The transmission report is printed with each transmission.
– If TX Fails: The transmission report is printed only if the fax could not be sent.
– OFF: The transmission report is not printed, regardless of the transmission result.
Feb 05, 2008 | Konica Minolta bizhub C250 All-In-One...
Print Fax Confirmation
The Bizhub C250 accepts the FK-502 Fax Expansion card like most other Konica Minolta Products so this data is relevant for many models. Below are the step to enable fax confirmation pages:
Press the fax button.
Press the Utility/Counter button.
Touch Administrator Setings.
Enter password (12345678) or (00000000) are the defaults.
Touch OK
Touch Report Settings.
Touch TX Report Settings.
Set TX Report to ON.
Close, OK, and/or Exit all the way out.
Oct 31, 2007 | Konica Minolta bizhub C250 All-In-One...
Minolta Di351 All-In-One Laser Printer Logo
44 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
