No power no picture no sound
My tv is 12+yrs old. the tv was shutting off by itself for a few seconds and would then come back on by itself. however now the tv will not come on at all. i push the power button the the tv and remote and nothing happens. power good to the outlet.
  • 89 Answers
I would say that its time to put that tv to rest is it a projection tv? if it is then it may be the bulb but i would recomend just getting a new set because repairing your current one will cost alot and wont last long so a new one is a better option
Posted on Jan 07, 2009
My tv is about 12 yrs old. it is a 32 '' when it warms up the picture goes out. as soon as it cools of it will restart, but only for a few seconds
Get a new TV, they are cheap enough now. It sounds like you have a Solder Joint problem and heat expansion is causing problems.
IMHO not worth the repair.
Oct 03, 2009 | Televison & Video
When turning on the TV, I hear a banging/grinding sound.
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Jun 14, 2009 | Samsung HL-S5087W DLP TV
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Mitsubishi WT-A42 projection 42" HD1080 series
It sounds like your regulator circuit is defective. Not an expensive repair, maybe $200.or a little more.
Apr 08, 2008 | Mitsubishi WS-65909 65" Rear Projection...
RCA TruFlat TV
You may have a loose solder connection on the circuit board inside your set.
You need to have a technician check it for you.
Stargazer
Jan 16, 2008 | RCA 27F530T 27" TV
Matsui television
1 it might be due to loose contact in plug or socket. 2 there might problem in power supply section in your tv.
Sep 17, 2007 | Televison & Video
TV turns itself off after a few seconds, no picture at all
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
