MY BIG SCREEN TURNS ON BUT ONLY FOR 15 SECONDS AND THEN PICTURE GOES OFF BUT SOUND STAYS ON? CAN U HELP? I HAVE A PHILIPS 50PL9126D/37 DLP
  • 2,326 Answers
Have you replace the lamp on this DLP?
Posted on Jan 07, 2009
  • Jaime Hernandez Jan 07, 2009
    There is more info on this link to know if the lamp is defective or something else.
  • 679 Answers
There is some setting proble.
so, set the settings as default by using remote.
Where is the power board for a phillips 50inch model #50pl9126d/37
Hello
As far as the lamp stays lit for a few seconds, all other voltages comes to the lamp and inverter board are OK. If the lamp has reached its life time, this type of fault can occur.
Feb 16, 2012 | Philips 50PL9126D/37B 50" DLP TV
Philips tv 50pl9126d/37 help
Hello your problem is you have a bad color wheel that needs replacing.
Nov 09, 2011 | Philips 50PL9126D/37B 50" DLP TV
I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
I have a Philips model Problem with the Philips 50PL9126D/37B 50 in. HDTV DLP TV I have a Philips model number 50PL9220D/37 and it turns off after about 30 seconds and a red light on the left hand side of the power button comes on. Not sure what to do.
Apr 22, 2011 | Philips 50PL9126D/37B 50" DLP TV
MY TV TURNS ON AND STAYS ON FOR 5SECONDS AND THEN THE SCREEN TURNS BLACK BUT CAN STILL HEAR THE SHOW PLAYING. TURNED IT OFF AND EVEN UNPLUGGED IT FOR ABOUT 5 MINUTES, BUT STILL THE SAME THING HAPPENS.
the lamp is likely bad .. they only work a few thousand hours .. then must be replaced .. your lamp can cost a couple of hundred (maybe even more if bought locally) .. here is one for less if you have someone handy that can change it.......
http://www.purelandsupply.com/50PL9126D-37-Bulb-Philips-DLP-TV-Bulbs.html
..... of course make sure power is off (unplugged) and make sure things are not hot .. there is usually a little cubby in the back where the lamp is located .. you an see what the lamp looks like at the above URL .. dont get finger prints on the bulb . that will cause it to crack when hot .. if you are unable to change the bulb then a call to philips service should do the trick. make sure you ask what the bulb replacement and labor will cost ..
Jan 27, 2010 | Philips 50PL9126D/37B 50" DLP TV
Do I need a new lamp?
99% chance your lamp needs to be replaced. Prices are in $120 -180 range. Search for "50PL9126D/37 lamp". they are available with or Without cage. Version with cage is preferred because it will be easier to install it.
Oct 08, 2009 | Philips Televison & Video
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Problem with philips dlp tv
This sounds like one if not both of your cooling fans are not functioning properly. Therefore, you'll need to replace a fan more than likely.
Apr 16, 2017 | Televison & Video
Philips TV, Model # 50PL9126D/37
Check to make sure all the ventilation opening on the tv arent plugged. if not, then you will have to make sure all the fans inside the tv are working properly.
Sep 23, 2007 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
