Question about Teac DVC200 System
TEAC DV-C200 won't play discs.
When loading a DVD or CD unit shows "loading" then "no disc" Disc doesn't spin nor does the laser move. The door opens and closes fine.
  • hankman1963 Mar 09, 2009
    TEAC DV-C200 will not play any discs. The top door opens and closes but reports "Loading" and then "No Disc". Radio works fine.
  • jmtinmi Apr 28, 2009
    I don't think this unit has worked but a few times. radio and cd seem to work fine.
  • 944 Answers
Here is the link to the user manual if you need it; Check especially page 64 of the pdf file - see if it sheds any light on the problem. If you get no luck from the info in the book, please ask again - i have the same model and have taken it to bits a few times so i should be able to help :)
Posted on Apr 12, 2007
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
james klgr
  • 362 Answers
SOURCE: My Teac dvd/cd-rewritable w28e CD-RW, won't read any discs!
if you just installed this device you will have to go to the utility manager and make sure all the functions are turned on, do you have windows xp. what os are you using and i can give you instructions how to go this.
Posted on Dec 09, 2007
SOURCE: PL-D2000 DVD Home theater System
Turn on the player for about an hour untill it heats up and then play the disc. Most probably it will work. If not you will have to replace the lens or card.
Posted on Dec 30, 2007
  • 3422 Answers
SOURCE: New Unit Teac DV H500
So the problem is that the player is not able to read the discs right?
Waiting for your reply..
Posted on Feb 22, 2008
When loading a dvd it displays, "NO DISK". Is it
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
My DRC6309 RCA portable DVD player will not play disc. It says "loading" and then says "no disc". I have tried different outlets and different discs. Any suggestions? Is there a...
Either your DVD players Laser Pickup Unit is dirty or defective or its 'sled' motor has damaged. Sled motor is one, which spins the disc inside. if it does not spins, the main system IC won't get any signal that the disc is "IN", and will show the messege "No Disc". The same will happen if the laser pickup unit is defective or dirty. Insert a Head Cleaning Disc into the system, and play it for atleast 3 times. If there is any dirt or dust, this will solve your DVD's problem. If not, it should be serviced by any skilled technician. It is not a user reparable item, as you have to take out its loading mechanism completly out of it for repair. OK.
Jun 02, 2011 | RCA DRC6309 9 in. Portable DVD Player with...
Disc is loaded we push play and the machine says no disc. We have tried a second disc with same results. Can you help?
Unfortunately the problem is in the laser pickup assembly, overtime the laser becomes weaker until it can no longer track a DVD disc. One option is buy a disc cleaning kit and follow instructions to remove dirt from the lens, if this fails you are further ahead replacing the DVD player.
Jun 02, 2011 | Teac DV-M5000 DVD Player
Wat should i do when is displays no disc
If your DVD player shows no disc, even a disc is inserted, try to clean its laser head assembly, by inserting a cleaning disc in it and play atleast three times. Take it ejected each time before you play it. If it does not helps, open the top cover of your DVD player, insert a disc, and notice if the disc spins or not. If disc spins, and not reads, the laser picup unit of your DVD player is faulty, and should be replaced with same type and number. If its stripe wire connected between pickup unit and main board is detachable, try repalcing the strip wire first. In some occations, bad strip wire will show this type of problem.
If disc does not spins, the sled motor [the motor that used to spin the disc at high speed], is damaged and shoud replace it. OK.
Apr 07, 2011 | GE DGE100N DVD Player
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Teac PD-1200 Compact Multi Disc Player
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
Jul 04, 2008 | Teac CD-P1120 CD Player
Marantz DV-6500 problem
Could be the laser Try cleaning it and if not Try and get it repaired Unless you wan't to buy a new one
Aug 03, 2007 | Marantz DV-6500 IN STOCK DVD Player
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Teac DVC200 System Logo
204 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
