Question about Mamiya 645 Medium Format Camera
Mamiya M645j film counter not advancing to start when roll loaded
I have an M645j that's having a problem where the film counter does not automatically advance back to the start when a new film cartridge is loaded.
I've heard that it could be a spring somewhere that's not working right, and the film counter otherwise works fine when I wind the gear back to the start with my finger manually.
How can this be fixed? Thanks
  • Anonymous Feb 27, 2009
    same
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Posted on Jan 08, 2009
How to replace sticky light seals on the back of vintage Mamiya m645j camera?
You should be able to get replacement light seal kits on eBay for most cameras, but they may need a little judicious trimming for a perfect fit.
Aug 09, 2017 | Mamiya Cameras
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
My Mamiya C330 Pro only gives me 4 photos per roll
A few things to consider:
-Loading: Make sure you are not over loading the film before you start to shoot. I have sometimes turned the film advance too many times and end up cutting down on the amount of usable film.
-Are you loading the film in a dark area and careful to close up the back just after it has started to load to avoid exposing it?
-Shooting: Are you metering properly when shooting? Obviously underexposed images won't develop. You should consider a hand held meter.
-Shooting: Are you advancing the film more than it needs to be after you take your shot? Watch the film counter and feel for that click as it hits the next frame. I have advanced past the next shot many times by accident.
Hope that helps, Matt
Apr 05, 2011 | Mamiya C330 F Professional TLR Film Camera
Mamiya 645 AF back won't advance film.
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Feb 07, 2010 | Mamiya 645AF Medium Format Camera
Pro-S film back doesn't advance film properly.
There is good chance that the back needs a spring replaced. I've seen them fail many times.
Nov 14, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
When film loaded it is not rolling on properly
film not advancing? film not rewinding? film transport motor dead/ needs replaced.
Rewinding but counter not resetting and light meter dead? Prolly bad connector or ic inside camera = repair shop.
Oct 16, 2009 | Photography
Film won't advance
Perhaps you've already solved the mystery. There are 2 parts to the back of that camera, the film back + the part that it slips onto. And they have little safety latches/pins that couple in order to advance the film & release the shutter. I'm sure those just aren't in the right place. Here in Los Angeles you could take it to any major camera store or repair shop & they've help you out.
Mar 06, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Mamiya 645 Medium Format Camera Logo
484 people viewed this question
Top Mamiya Photography Experts
Tony
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
