Question about Panasonic NN-S262SF Microwave Oven
How do I remove my Panasonic OTR microwave for service?
Hi Guys, would you happen to know how this NN-H264SF was installed?
I need to remove it for service.
Thank you for your help.
Matt O
  • bottomje Jan 11, 2009
    The unit is dead, and I am replacing it. However, I didn't do the first install so I'm unsure of how to remove it from over the range.
  • William Miller
    William Miller May 11, 2010
    You can
    download your Panasonic owner's manual
    here.
    It should have installation info.
    What problem are you having with it?
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave NN V622m locked
To lock, press START 3 times. To unlock, press STOP/RESET 3 times. If this doesn't work, contact Panasonic Support at http://www.panasonic.com/support/
Posted on Apr 10, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Panasonic NN- A712 combination Microwave 1000w - Switches off after 20 seconds
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Operators manual for NN-ST656W Panasonic
Your search is complicated by the fact that this is an Australian model.
Your manual and other documents related to this model can be downloaded from this page.
Posted on Aug 03, 2008
SOURCE: panasonic otr microwave model nn-s245bf,
I have the same problem. The control board (central processor) has caught fire. It's noticeable when you take the control panel off.
We need a new control board. I'm currently looking for how to get one. It appears to be a common problem.
Posted on Jul 05, 2009
  • 4090 Answers
SOURCE: Panasonic NN-H264SF Microwave oven starts with a chirp
No I dont think so, check that the wheels on the rotating ring are not seized up and dragging. These will make a chirp type sound as it starts to rotate or even when it finally comes to rest.
Please rate our help++++Thanks for using FIXYA
Posted on Oct 09, 2009
The top right corner of my panasonic nn-h275 otr microwave door leaves a approx. 3cm gap when closed. Fixable? Dangerous?
If the door is warped cheaper to replace the whole oven, the 3cm gap is a hazard because you have dangerous radiation leakage, the levels are exceeding safety standards and should be removed from service immediately.
Mar 27, 2011 | Panasonic NN-H275 Microwave Oven
I belong to thiruvalla and need to service my panasonic microwave oven(NN-C784MF)-28L.I need to know the best person to call.
Due to the type and design of your microwave oven, consult an Panasonic authorised service centre.
www.panasonic.com for a list of dealers in your area.
Jan 07, 2011 | Panasonic NN-S541 Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Oct 09, 2009 | Microwave Ovens
Hi, I just installed the NN-SD297 OTR microwave. I must have done something wrong. I have steam and a bit of grease running down the wall. Looks like it might be coming from Behind by the rear bracket. It...
Sounds like you didn't block the top vents. If it is not vented the top vents must be blocked and a carbon filter added . The metal plates you added don't appear to be air tight.
Oct 27, 2017 | Panasonic Microwave Ovens
User manual lost
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Jun 29, 2009 | Panasonic NN-SN657SMicrowave Oven
Panasonic otr microwave model nn-s245bf, ventilating all the time, cannot use as microwave. thanks
Jun 16, 2009 | Panasonic NN-P794SF Microwave Oven
Panasonic NN-H264SF now requires holding a control panael to operate
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 28, 2008 | Panasonic NN-H264 Microwave Oven
Panasonic NN-S262SF Microwave Oven Logo
76 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
