Question about Canon CanoScan FB630P Flatbed Scanner
Error Code ox24050010
I have recently changed my computer still using XP windows though. I was running my scanner through photoshop. It worked very well on my old computer. Now when I try to preview my pic for scanning I get error code 0x24050010 help it is driving me crazy. Thanks all
  • 1 more comment
  • catharine rhodes Jun 02, 2007
    Thank you so much foryour reply, however meanwhile I had aready gone to Canon Australian website and downloaded a new Driver for my scanner. This corrected my problem.
    Sincerely Catharine Rhodes Healesville Vic. Aus
  • Anonymous Dec 27, 2007
    I have tha same problem, when I want use the scanner I recieve error code ox24050010, please help me for this problem. thanks
  • jsmith67 Sep 05, 2008
    I have changed my computer and loaded the cd for my cannon scanner. I also keep getting the error message. I have treid downloading a driver from the we but not sure if it is the correct one. Still have problem. I would appreciate any help.
  • 883 Answers
Sounds like a proprietary TWAIN driver from Canon must be installed...try forcing driver from cd under current devices driver...under device manager, look for imaging devices, then right click-properties then driver-update driver...make sure cd is in
Posted on May 30, 2007
Well, i had this very problem here using windows vista.
i'd learned thru canon's website that there was no solution other than buying a new scanner.
it was a lie. after months trying to solve this i just came to a simple solution.
after installing my old drivers, i got to the settings tab and changed the default profile to my monitor's one. it works now fine here. even if the "scan" option is grayed, i just select the "save" option, and it does the work.
Posted on Nov 08, 2008
Photoshop cs4 serial
What version of Windows are you using? Changing the font sizes for one specific application would be difficult, though it is possible to do this for the entire operating system relatively easily. I know everything between Windows XP and Windows 8 allows you to change your DPI settings, which would increase the size of buttons and text system-wide. However, some versions of Windows let you specify your preferred text size in the Accessibility section of the Windows Control Panel.
Sep 30, 2013 | Lenovo Computers & Internet
Photoshop 5.5 r6025 error web
If the operating system is windows 7 or above the XP software will not run, it has to be compatible with windows 7 up.
Apr 20, 2017 | Adobe Computers & Internet
No scanner detected. Error Code 0x00070800. Using Windows Xp!
Your scanner may not be compatible with windows xp. You may need to see if the manufacturer's website may have driver files for your scanner.
Sep 16, 2012 | Office Equipment & Supplies
Hi, am using Adobe photoshop cs4 extended. Recently when am opening the photoshop am getting the error message that "adobe photoshop cs4: photoshop.exe-entry point not found". and " the...
Which Operating System is running on your computer? If it's Windows XP, you need to delete a file with the name "dwmapi.dll" in the C: drive's System32 folder under Windows folder. If I am right, the problem might have started after installing Mozilla Firefox. The reason is a wrong driver of Windows Vista installed on Windows XP system.
The process is like this:
Open My Computer, then "C:" drive, and again "Windows", locate "System32" folder and again locate "dwmapi.dll" in the System32 folder and delete the "dwmapi.dll". That should definitely do the trick.
Good luck.
Thanks for using FixYa.
Nov 17, 2010 | Microsoft Computers & Internet
Sterownik vista Mustek ScanExpress 1200 UB Plus
From reading around, there isnt one....But i found this post
I've just installed a Mustek 1200 CU scanner on Vista.
I used the XP driver from the Mustek website.
You have to temporarily edit the registry to make the installer think you have XP
In regedit, go to
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\Cu rrent Version
Find the "product name" key. Carefully record what it says before you start. (eg paste it into a document somewhere).
Then change it to make it read: Microsoft Windows XP
Then run the Mustek XP installer, and change the registry key back to saying Vista.
The scanner works fine in Photoshop, for example, but the Vista scanning wizard doesn't detect the scanner. Don't think it uses TWAIN?
Aug 11, 2010 | Mustek ScanExpress 1200 Flatbed Scanner
Error 112 when attempting to install Adobe Photoshop LE
Error 112 is a standard Win32 error code and represents an out of disk space error.
Photoshop 5 Requirements
* Windows:
* Intel Pentium processor
* Microsoft Windows 98, NT 4.0, 2000, Me, or XP
* Internet Explorer 5.0, 5.5 or 6.0 (updated with applicable service packs)
* 128 MB of RAM
* 150 MB of available hard disk space
* Color monitor capable of displaying thousands of colors at a resolution of 800 x 600 or higher
* CD-ROM drive
May 02, 2009 | Computers & Internet
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
How can I get my epson GT 700 scanner to work on windows XP
Once it is installed on Windows XP you can change the setting in properties to run Windows 98 compatible. It used to work with older scanners and printers. Try it out.
Dec 04, 2008 | Epson GT 7000 Flatbed Scanner
Lexmark X1270 scanner problem
The only way i can get my Lexmark X1270 to scan is to use the Windows Vista "Windows Photo gallery" to scan :
Start > All Programs > Windows photo Gallery > File > Import from Camera or scanner > select the scanner > save scanned file to your computer
This is the only way I have been able to use the scanner on my lexmark X1270,hope it works for you too.Be lucky.
FossyBear
Dec 11, 2007 | Lexmark X1270 All-In-One InkJet Printer
Error Message-- Error in shading position (-4431)
The issue at hand here is a sensor error. Cut the power to the machine for at least five seconds. Then reboot the scanner and the sensors should reboot. This solved the problem for us. Good luck to you.
Nov 21, 2006 | Canon DR-2580C Path-Through Scanner
Canon CanoScan FB630P Flatbed Scanner Logo
734 people viewed this question
Clive
Clive
old marine
old marine
