Question about Compaq Armada M700 Notebook
Compaq armada m700 power failur...
When plug in power cable only charging status led (red & green) are blinking and not power on laptop..... before some day it's working but after 30-40 minutes automatical power off... plz give me quick solution....
  • amit kathavadia May 31, 2007
    I have removed large battery and tryed but don't power on... only red and green leds are blenking.... what's i do.....
  • Anonymous Jan 20, 2008
    i have a satelite pro 6100 and plug in power and shows charging but when turn on power go 2 orange lite flashing
I had a similar problem, it turned out that my power cord had been damaged and the battery had completely drained.
So try replacing your power cord, if that doesn't work then it's probably the internal power supply.
Posted on Aug 30, 2008
The DC power socket on the main board can cause problems charging. I had the same problem on mine, bought new one on ebay.
Posted on Jul 14, 2007
Get a new battery. That seems to be the problem. Laptop batteries usually last only about 2 years or so. After that the li-ion cells die. I got a compaq armada M700 battery for my laptop. It solved the problem.
Posted on Jun 16, 2007
  • 883 Answers
Try removing the large battery and powering off wall supply only...if ok, then replace battery
Posted on May 30, 2007
Yellow led blink 8 times compaq m700
I'm not understanding what the problem is. If the battery is dead, and you remove it, how do you expect it to recharge? Why would you remove it? So, you take it out and nothing happens.So? What were you expecting to happen?
Before you do anything more, read the documentation that came with your laptop to learn how to care for your battery. The amber light usually blinks with the battery is running low. When you plug in the A/C adapter, the light usually becomes steady to indicate the battery is charging. At tleast until you remove it.
Hope this helps. Please rate this repsonse
Randy
Aug 31, 2012 | Compaq Armada M700 Notebook
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
Stuck in standby
Have you held down on the power button for more than 10 seconds to be sure the unit is off?
If not unplug power cord and remove battery if all else fails
Nov 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
BATTERY
should start charging when u plug it in leave it on it 4 5 hours then cheak status in woindows of battery ok or bios
Jan 19, 2008 | Compaq Armada M700 Notebook
Compaq armada M700 power on problem
HMMMMMMMMMMM, SOUNDS LIKE SOMEONE NEEDS A INVERTER! YOU CAN BUY ONE OF THESE ONLINE, BUT UNLESS YOU KNOW HOW TO PUT ONE IN DON'T DO IT.
CHECK TO SEE IF THE DISPLAY WORKS BY PLUGGING A VGA CORD FROM YOUR NOTEBOOK TO YOUR MONITOR IF YOUR MONITOR SHOWS WHAT YOUR NOTEBOOK IS DISPLAYING, THEN IT'S YOUR INVERTER.
Dec 17, 2007 | Compaq Armada M700 Motherboard
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
My laptop armada m700 gets no power
the hard drive was damaged. Inside the drive, the tiny moving head took the hit. They really are not designed to take shocks like that. Many laptop mfgrs offer "industrial" duty laptops that have on-board shock absorption suspension for hard drives.
Aug 26, 2007 | Compaq Armada M700 Notebook
Power failure
Hi Asadi Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps. Regards Harry
Jun 14, 2007 | Compaq Armada M700 Notebook
Power failure with compaq amarda
DC Power Jack is most like defective. Typically bad/cold solder joint. Since this is a 3 state 2 prong jack, it would be best to locate and OEM Jack and replace- simply reflowing or resoldering does not always fix it. 3 State means the battery will charge with AC on and Laptop off the laptop will work with the AC on the laptop will work with the AC off and battery charged Worse case scenario an on board fuse blown (rare) Don't forget to rate me - Why? Because if I don't know if answering helps, I'll stop posting.
Nov 23, 2006 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
351 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
