Hi, I have a honeywell combination boiler. It stopped working and there is a red triangle flashing and the little window says EA. The round pressure window shows that the pressure (I think it is pressure) is on 0. Please help i am frezzing. Thanks
  • 30 Answers
I am not familliar with that boiler but most will not run if the pressure is too low try refilling the boiler from the fill loop if there are no signs of water leaks
Posted on Mar 26, 2009
After moving my gas meter from inside the home to outside and having a semi concealed meter connected we cant get the combi boiler to work properly we can get hot water and have the gas fire on but
your boiler needs a minimum gas pressure of 16 mb to light successfully. if your gas pipe has been extended it has to be able to flow enough gas. it may need upgrading to 28mm for even as little as a metre from the gas meter. if your central heating works ok when the fire is off then this is your problem
Oct 12, 2014 | Water Heaters
Biasi combi boiler with red light flashing at honeywell r6660d
Here is the biasi site that should have your manual. With no model number, I hope this helps.
Feb 15, 2014 | Honeywell Programmable Thermostat Heater
Boiler ignition failer
Try adjusting the gas to air mixture and flow rate. I don't work well in very cold weather, either. I think that's fairly typical. Even a diesel engine is difficult to start in cold cold weather. Perhaps heating the room where the boiler is would help or at lest insulate the room well. Including stopping any drafts that may be causing a windy condition in or around the combustion chamber.
Feb 06, 2014 | Honeywell Triangle Tube Prestige Solo 110...
Ariston microcombi 23 mffi Boiler Manuals
its the air pressure switch. needs replacing. they are quite cheap but it could be something a little more expensive but you wont know until you replace it. easy half hour fix
Nov 06, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
High pressure
1)If its going into the red,it will more than likely be
relieved in the automatic relief valve, which you really dont want to happen.
2) You must have a vent somewhere on the system
that either autmotically relieves pressure or you have
to manually relive pressure.
3) Look for a autovent. Which is round and usually
installed somewhere at the highest point of the system. If you have one,there is a little round cap
on top of it, screw it tight and then lossen it until
you have air coning out.
4) it sounds like you have air in the system and you
need to get it out.. If you can turn the boiler off
but keep the pump running , either way you have
to get the air out of the system
Jan 09, 2010 | Heating & Cooling
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Hi There, I have an Ideal Response 120 Combi Boiler. Each day the water pressure falls to 0 on the pressure gauge. In order to get hot water and Cental Heating I increase the pressure to 1.5. The Hot water...
I have the same boiler with a similar issue. The water is more than likley leaving the system from the pressure relief valve, which will be routed outside. It sounds like you have lost the pressure in your expansion tank, which is inside the boiler. With the boiler pressure at zero and the power isolated, the expansion tank can be accessed from a panel at the top of the boiler on the right hand side. You will see a valve on the red expansion vessel like the one on a car tyre and can be pressurised with a car tyre air pump. I think from the manual the pressure should be about 1 bar, but it depends on the length of pipework on your system. A competent boiler engineer should be able to sort this out, but it may be that your valve is leaking, or the expansion vessel has failed and the problem will occur again.
Nov 10, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
