Question about HP Deskjet F340 All-In-One Printer
Power cord is damaged and needs replaced
The power cord for my HP deskjet F340 is so damaged that it will not even plug into the back of the printer. I would like to just replace the cord, as the printer is realitively new and other than the cord, it works great. I went to the Office Depot here in Casper, WY and the clerk told me that I couldn't replace just the power cord and that if it was possible, there is "NO WAY you'll find it locally..." Is this true or was I misinformed? The problem is simple and I would think that it is not "impossible" to replace only the power cord... The printer itself has NO damage whatsoever, I believe that the end of the power cord that connect to the printer was possibly stepped an or something. Please refer me on this problem.
    Scholar:
  • 149 Answers
I am not in any way offiliated with the following website but it was the first one to come up in google
http://www.sparepartswarehouse.com/HP,Printer,Part,09572119.aspx
bearing in mind the part is quite cheap there must be lots of places you can obtain a spare/replacement power supply...and if they are sold seperately the clerk that gave you the advice about not being able to replace just the power cord must have been having a bad day/year/lifetime
Posted on Jan 26, 2009
I need a replacement installation disk for my printer its the hp deskjet f340
replacement disc can be obtained by contacting hp tech support(depends on ur warranty)
alternatively u can download the drivers and s/w from www.hp.com
Sep 16, 2010 | HP Deskjet F340 All-In-One Printer
Can you use the HP 27 Ink Cartridge with the HP Deskjet F340?
No you cannot use Cartridge 27 with Hp Deskjet F340 printer. The printer only supports, 21 (black), 22 (color) and 58 (photo). I hope this clears your doubt.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 04, 2010 | HP Deskjet F340 All-In-One Printer
Hp deskjet f340 all-in-one-copier and a new computer no cd
Hi. Just go to this link and choose your operating system. After that download your driver for that deskjet printer. I love you.
Jun 07, 2009 | HP Deskjet F340 All-In-One Printer
I need to find a cord that goes into my HP deskjet scanner/copier
You want a USB printer cable. You can get it at any store that sells electronics or printer supplies.
I added a link to the users setup manual so you can see what you need.
HP F340 users guide
Mar 19, 2009 | HP Deskjet F340 All-In-One Printer
I need to find the grey power cord for my HP Deskjet F340
Computer equipment stores should have those 3 prongs power supply.
Radio shack sells them as well.
It does not have to be gray as long their the same size plugs. 95% at a time they are compatible.
I hope this helps.
J-inno
"Job security hijacked by bad economy---how secure is your?
Start a recession proof 24/7 side income---click and learn how?
Feb 27, 2009 | HP Deskjet F340 All-In-One Printer
F340 printer
Hi Pear,
I'm sure that this is an Hardware issue, this could be fixed by resetting the printer.
Step 1: [Power Drain]
>>Turn off the printer by disconnecting the power cord from the back and also disconnect the power cord from the wall outlet
>>Then Press and hold the ON button for 30 seconds.
>>Connect the power cord, if it did not work go to step 2.
Step 2: [ NVM Reset]
>>Take out the Ink Cartridges out.
>>While the printer is on, unhook the power cable from the back of the printer.
>>Press and hold CANCEL and PLAIN PAPER button simultaneously, while holding these two button insert the power cable and keep holding for 10-20 seconds.
>>Release the button and check the printer.
>>If the problem exist, service or replace the printer by calling HP.
Thanks
Rizwan
rizwan84tx@gmail.com
Jan 02, 2009 | HP Deskjet F340 All-In-One Printer
HP deskjet f340 all in one printer
its the problem in your adaptor for sure.but before going for the new adaptor please check the jack of the printer where you connect the adaptor is loose or slightly pressed inside or looks any thing like damaged.if not then try in another electric outlet.also try with different power cord wire which you connect in the adaptor the three pin adaptor.that is near about less then 2$ if you want to replace.and if still does not work then its the adaptor you have to replace.that will cost u near to $10.
you can get it through
www.radioshack.com
Sep 21, 2008 | HP DeskJet F380 All-In-One Printer
POWER SUPPLY
www.hp.com may be the only place to find that..
Jun 27, 2008 | HP Deskjet F340 All-In-One Printer
64 people viewed this question
Ben Johnson
