Question about Kitchen Ranges
Oven does not work on bake it does on broil - Kitchen Ranges
  • 242 Answers
Hello , I can help , this can be 1 of 2 things , 1 is the bake element-you can visually inspect it to make sure there are no openings , blowouts , boils , corrosion etc.
if the element looks ok it can still be bad , you must have a meter to check the element , set the meter to ohms and it will ring or be a low number to check good.
Problem 2- your control board is bad and needs replace.
let me know if you have any other questions.
Phil
Posted on Jan 07, 2009
  • Phil Brantley
    Phil Brantley Jan 07, 2009
    Phil
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Frigidaire oven fefl68 broil element comes on on broil only will not come on on bake or clean
Hello - - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Nov 17, 2012 | Ovens
Why has both top elements stop working at the same time
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
I have a G E Spectra gas stove and oven the gas oven doesn't work
does it not bake or broil? if this is the case, it could be the control panel. however if one or the other of the bake and broil functions work then it would most likely be an ignitor. check to see if your broil and bake ignitors glow. to access the bake ignitor you must remove the bottom panel from the oven but you can probaly see it gowing without removing the panel. the broil ignitor should be in plain sight.
May 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Dec 07, 2007 | Whirlpool RBS275PD Electric Single Oven
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
