Why when I record a protools session why does it wait a few seconds then starts?
    Sergeant:
  • 367 Answers
It is taking the time to process the audio file. Let me know if this doesn't work for you
Posted on Jan 07, 2009
Hello There, I just bought the Rode NT1-A, and I am trying to record in protools, but i'm not getting any levels whatsoever. I'm plugged in to an MBOX, in the XLR, I have Phantom Power turned on,...
It sounds like you have done everything right. It would be a good idea to check both the mic and Protools system separately. If you can, verify that the mic works using another device such as a mixer. Also try getting a level into Protools using another mic, preferably a dynamic which doesn't require phantom power. If you are trying to use an original MBOX under Windows 7 or the latest version of OSX then it may not work at all.
Sep 19, 2011 | Rode NT1A Professional Microphone
I can record voice, but no guitar. Just as many people on this forum, but i didn't saw a proper answer for my problem. I can hear my guitar im using pro tools SE. The light on my fast track lights up,...
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
Sep 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
I had to reset my computer but before i saved all my protools sessions to a disk now when i go to open them i get this message. "The original disk allocation for this session cannot be used. Check the...
Hi rfanklin65,
Did you remember to save the audio file folder to the disk as well as the session data? If so, are the audio files on the same disk as the Pro Tools sessions?
Are you running a Windows or Mac system?
Thanks, Krisfaudio
Apr 30, 2011 | Digidesign Mbox 2 Barebone
Mbox cannot start new session or load in old sessions.
Digidesign website had the answer....go to windows,show workspace and change the settings for your relevant disc from transfer T to R...record in the A..audio column.
Thanks  Bobcat8
Oct 07, 2008 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
Hiccups in digital 8 playback
I actually haven't fixed the problem- I asked you though yesterday to provide me with an answer as to why my online session with one of your experts expired after only a few seconds.
I'm still waiting for an answer, and an opportunity to go back again and get a real session going.
Thanks. -paul
Jul 06, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
I have a snap back delay when I try and record using my m-audio and protools. I can hear a slight delay in my headphones to what I'm actually playing. How do i get rid of this?
Hi emmastevens
what you are hearing is latency(delay) in the electronics, software, and maybe your computer is producing some problems also. Have you tried to monitor yourself direct from a mixer before you feed the signal into the MBox.
regards
Graeme
Apr 08, 2008 | Audio Players & Recorders
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Trying to get my Marshall to work for first time!
Hi! you are trying to bite off a bit more than can be chewed at once.
you need to troubleshoot backwards
Step1:- check normal playback. Sometimes the speakers (headphones)are not properly connected or the sound card needs to be ascertained. Just playback anything and eliminate this stage as a potential problem
Step2: We have now ascertained that the playback is not an issue,Now we need to check the USB hub - Computer connectivity. Try to connect someother USB device like a pen drive ascertain that this section is working. If it isnt go to strat - settings -control panel- Administrative services- computer management - Device management - and configure the USB Hub
Step 3: Having ascertained that the USB Hub is indeed wiorking connect MBox to the USB hub and load driver software open page, start- settings-control panel - Administrative services - computer management - device managment and check thet the driver is installed and working properly.
Thats it it should work fine if the above steps have been completed.
Nov 05, 2007 | Marshall MXL2003 Professional Microphone
Computers & Internet Logo
David Payne
David Payne
