Question about Kodak EasyShare V1003 Digital Camera
Memory card format for v1003
How do i do this
thanks for the help
craig
  • Rob Houg
    Rob Houg May 11, 2010
    You should be able to use it right from the package.
    Problem Solver:
  • 10 Answers
GO INTO THE MENU MOVE UP ONE CLICK (WITH THE TOGGLE) SO YOU ARE ON THE SETUP MENU PRESS THE SELECT BUTTON GO DOWN TO FORMAT AND FOLLOW THE INSTRUCTIONS
Posted on Feb 07, 2009
I have a V1003. It is saying memory card is protected (reset switch on memory card).
move the switch on the memory card, then put it back into the camera, if its still locked, take the card out and look did the switch move to the other posititon? if it did, then something is touching the lever as you put it in the camera.
if it did not move but the card is still locked. try formatting the card with the format option in your camera, if that doesn't help then the sensor in the camera that detects if the lever is on the locked position or not is jammed and thinks the card is locked, to fix the problem the sensor needs to be fixed, you need to take the entire camera apart to get to it.
May 30, 2011 | Cameras
There are several possible causes for "memory card locked/protected", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card (which you said you've tried), or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 30, 2011 | Kodak EasyShare V1003 Digital Camera
My screen says 'internal memory is full' I have only taken about 50 pictures. I then bought a new memory card but after 3 pictures the same message comes on screen.
You need to look at your image storage settings. Press "Menu", "up/down" and "OK" to choose "Image Storage"; is it set to "auto" or "internal"?
If it's set to "Auto" then there's some reason that it's not recognising your memory card. You should format it. Press "Menu", "up/down" and "OK" to choose "Format" and then select the memory card.
If it's set to "Internal" then you need to set it to "Auto". Then it will use the memory card if it's inserted. (Take the card out to access the photos in Internal Memory.)
Feb 01, 2011 | Kodak EasyShare V1003 Digital Camera
I have a Kodak EasyShare V1003 Camera which I received as a gift. I have the memory card and wire attachments but I do not have an instruction manual. Can you please list the manual so I can print it out? ...
Getting started guide:
http://support.en.kodak.com/app/answers/detail/a_id/18750/kw/v1003
User guide:
http://support.en.kodak.com/app/answers/detail/a_id/18747/kw/v1003
Dec 27, 2010 | Kodak Cameras
How to reset a kodak v1003
my v1003 camera is saying reset switch on memory card. I can not take any pictures at this point and I don't see instructions in my Easy Share manual. I'm on my way out of town it is 6:28am and my camera won't work. can someone please help me. thank you
E.J
j54jackson@yahoo.com
Aug 29, 2010 | Kodak EasyShare C743 Digital Camera
One 4 GB SD card gives trouble on my V1003 camera
card problem may be some virus on ur card chaing ur card
Jul 11, 2009 | Kodak EasyShare M1033 - black Digital...
What is the upper limit of SD card as GB without any freezing or slowrunning problem in Kodak easy share V1003?
I have a 2 GB SD card that i use on mine, and i dont seem to have any problems with the camera being slow. I hope this helps and good luck!
Jul 13, 2008 | Kodak EasyShare V1003 Digital Camera
Kodak EasyShare V1003 Digital Camera Logo
95 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
