Question about Motorola Mobility RAZR V3
As soon as i open my phone it automatically tries to voice record
And when it always tries to voice record i cannot use any other buttons as the voice record jams it, everyu now and then it stops for 3secodns then starts again \ what can i do here? i would be really thankful cheers, tom
  • 883 Answers
Remove the battery for 15 minutes, then try again. if no-go, then look for a small pinhole to reset it
Posted on May 30, 2007
SOURCE:
How to activate voice dial phone feature
Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working.
Step 1
Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag."
Step 2
Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one.
Step 3
Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial."
Step 4
Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program).
Step 5
Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
Jun 20, 2016 | Cell Phones
Ringtone for LG Scoop
if you want the voices of your relatives and friends recorded and personalized a your ringtone for them,follow the steps:
1.you go to the menu and you click on multimedia,you find the voice recorder there
2.you tell your family and friends or whoever person you want to keep talking and you record their voices,it saves automatically in the sounds located in "my stuffs"
3.you now go to your contacts,click on contacts you will find your groups i.e family and friends,you click on options,you will find the group ringtone,you click ok,immediately the sounds stored on your phone opens including the recorded voices and you click ok on the desired voice for the group or persons
Feb 27, 2010 | LG VX8300 Cellular Phone
Sony ICD-P320 Handheld Digital Voice Recorder switch on and off
This voice recorder have auto power off function so does not have particular power on-off button, press play/ record to turn on and leave it for some time to turn off automatically.
Nov 11, 2009 | Sony ICD-P320 Digital Voice Recorder
How do I record on the motorola peble?
Hold down key "1" then automatically calls to voice mail.
Check if your voice mail number is correct!
Aug 08, 2009 | Nokia 6230
Voice Recording Full
Depending on how your razr is set up, you should be able to click on the "settings" button, then click the "tools" option, which will open that sub-directory, then scroll down to where it says "voice records", open that, and then click the menu bar (the one that looks like a flat bar like --- ) and then it should give you the option to delete it.
Jan 03, 2009 | Motorola Mobility RAZR V3
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Record to PC window won't open
go through device manager and update driver for the device
Jun 26, 2008 | Olympus VN-2100PC Digital Voice Recorder
Voice record!!!!!!!
Press the big side button on the right. Hold it down while the phone is flipped open. Then it should work, hope this works.
Jun 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
47 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
