Question about Hunter 27187 Remote Control
Installed new hunter westminster and the lights work but no fan. and how do i get my hunter remote to work with fan?
  • 10,865 Answers
Begin by unscrewing one wire nut at a time to be sure that the wires are tightly twisted together before the wire nut is reinstlled. Once you have the fan working manually, the remote will also work.
Posted on Apr 06, 2009
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Dec 30, 2012 | Hunter 52" Ceiling Fan With Light And...
Where i cand find capacitors for hunter ceiling fans
I had a replacement pull switch from lyon lighting, I think they also do the capacitors.
Cheers
Feb 14, 2011 | Hunter 28096 Westminster 52" Ceiling Fan...
After installing new fan, lights work, but fan doesn't.
Make sure that the fan was connected in the unit. If there is no manula control then you must check if the connection has come off in the dual assembly. Check the fan coils and the connecction to the starter capacitor. If open connect, if there is connection to the unit check for failure of the line.
Aug 29, 2010 | Hunter 28096 Westminster 52" Ceiling Fan...
We purchased a hunter grand visita and when we turn the light on a the breaker box or the switch plate there is a delayed reaction before the light comes on whats going on?
Here is what hunter technical support says about this.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Mar 01, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Not working
How old is it? If it is more than a couple of years old, the motor windings for highest speed probably failed. They can not be repaired as cheaply as buying a new fan.
Jul 18, 2008 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter Fan with Remote
Contact Hunter Fan and they will send you another ceiling remote. Just received mine but have not installed yet. Good luck. Len
Apr 27, 2008 | Hunter 52" Ceiling Fan With Light And...
My Fan makes a kncking sound when it runs on high speed
The bolts might be loosely fitted. So try to fit them tight
Jan 23, 2008 | Hunter 28096 Westminster 52" Ceiling Fan...
Hunter 27187 Remote Control Logo
364 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
