Question about Philips 42PF9946 42 in. EDTV-Ready Plasma Television
Philips 42" Plasma TV
My Philips 42" Plasma TV brokedown in May 2007, model 42PF9946/98. Philips technician have checked and confirm the faulty PCB is on the Power Supply module If any of you have an old unit which is beyond economical repair, appreciate if you would contact me. I willing to pay for right price for the old unit but provided the faulty part should not be the same like mine. Phua sy_phua@yahoo.com 96263023
  • Anonymous Dec 17, 2008
    My Philips 42" Plasma TV brokedown in August 2008, model 42PF9946/98.
SOURCE:
  • 2337 Answers
SOURCE: philips plasma power supply
The power supply is very expensive. The existing power supply can be fixed too.
Check this link for more info.
Ask this guys if they have one as well.
Posted on Mar 11, 2008
pizzaguy3274
  • 4 Answers
SOURCE: 42fd9954
Not a fix, but it got my tv on.
I removed the back and tried the power switch.
I located the relay that was clicking.
I have two blue relays in the middle of my power board.
I placed a hair dryer over the relay for a few minutes.
After four tries of the power switch and it stays on!!!!!
Heat keeps the relay from just clicking off.
I don't know why.
This will at least get the tv on though.
Posted on Apr 12, 2008
  • 70 Answers
SOURCE: Philips Plasma 42" - constant purple haze
all philips plasma sets have issues with overheating heatsinks.
any heatsink that burns you upon contact is a recipe for disaster.
using cooling fans on these overheating parts will generally provide
great reliability in the long rung.
Posted on Nov 10, 2008
SOURCE: 42 plasma philips
I had a similar problem. You likely have 1 or more bad capacitors on the power supply board. You can easily identify them - they have a raised or rounded appearance on the top instead of being flat. Remove the power supply board and take to electronics repair shop and have them replaced. The capacitors only cost me $4.24 for two. Now mine works fine. The repair man replaced them for free. It took him only 10 minutes to solder them on the board. Easy, cheap fix but manufacturer won't tell you that. I fixed this on 1-02-09. My 2 bad capacitors were "3300uf 10v" and I replaced with "3300uf 16v" but you might be able to replace with "4700uf 35 v" also.
Posted on Jan 03, 2009
SOURCE: Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Posted on Mar 31, 2009
I have a philips 42 inch plasma that requires a power supply board.... model number 42pf5331/10 serial number vn1b063801737.... adrienpatrickking@hotmail.com
Tries websites like Shojimmy.com,Ebay.com to buy the whole refurbish power supply board.Can't find in catagories in data base in search.Ask help desk,send Email ask questions.Shopjimmy.com,Ebay.com have the most use refubish PCB for LCD,Plama tvs boards around the web.
Jul 30, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 42pf5520d faulty
Hi, the power supply board has a little board towards the connectors. This board has an led and it will blink if there is an error, check how many blinks there are and then check on the on the power PCB next to this little board you will see the error explanation. Also check capacitors on the power board next to the control board connector, replace any bulging ones. I hope this helps.
Feb 01, 2010 | Philips 42PF5520D 42 in. EDTV-Ready Plasma...
I have a 42 in philips tv that wont turn on green light comes on
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Jun 25, 2009 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 inch HDTV - "FlatTV" Plasma -- does not turn on.
Jun 20, 2009 | Philips 42PF9631D 42 in. Plasma Television
42 Philips Plasma 42pf5321d/37 green light on no AV no Menu nothi
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Tv red blink no start42 plasma philips
May 07, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42'' Plasma TV 42PF7320A/37 red led error codes
Mar 08, 2009 | Philips Televison & Video
Black Vertical strie on plasma TV
I think you have a frame fault on the tv. If you are capable check the picture frame board first. If not find a competant technician. Good luck.
Oct 02, 2008 | Philips 42PF7220A 42 in. Plasma Television
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
Philips plasma 42pf5520d pictures has gone?
My Philips Plasma TV model 42PF7220A/37 went into "no menu exit" mode on 11/28/2007. I went to www.usasupport.philips.com and downloaded an upgrade. Just followed the instructions and my TV is all better.
Nov 21, 2007 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9946 42 in. EDTV-Ready Plasma Television Logo
56 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
