Question about Indesit W 123 Front Load Washer
Replaced temperature sensor & F-03 is still showing
I have replaced the temperature sensor and it is still flashing the f-03 warning....help
  • lisatrainor Jan 10, 2009
    Many thanks for your assistance on both occassions, sorry for not rating your initial suggestion in the first instance, I have now rated your suggestions. I managed to find the part in the machin without any difficulty, apart from the pulling out of the machine from the laundry cupboard, it was easy enough to swop the parts over following your instructions.
    Again many thanks.
  • Indesit Master
  • 3,463 Answers
I provided a solution for you on how to replace the temp sensor on your washer, which you did not rate, or comment on, now I see you are asking why it does not work.
F03 indicates wash thermistor is open circuit, but this is only an indication of the problem, not neccesserily the solution, as other components could be involved, including the main pcb.
PLZ rate my solution.
Thankyou.
Posted on Jan 07, 2009
Jetta Warning Light
It says that your vehicle is low on coolant.Get the coolant level checked.If low has to be changed.
------------Check out few help links related to your issue.Click the link below:---
Service 4wd warning light on Dash? http://howtobyme.blogspot.com/2011/11/service-4wd-warning-light-on-dash.html
Car Turns OFF due to low oil pressure warning light? http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
Hybrid warning Light ON? http://whatisbyme.blogspot.in/2012/05/2005-toyota-prius-hybrid-warning-light.html
Order Coolant Bypass Tube? http://whatisbyme.blogspot.in/2012/05/1991-toyota-camry-order-coolant-bypass.html
Coolant Leak? http://technoanswers.blogspot.in/2012/04/1994-toyota-camry-coolant-leak.html
COOLANT LEAK AT DRIVER SIDE NEAR FIREWALL? http://schematicsdiagram.blogspot.in/2012/04/2006-cadillac-dts-coolant-leak-at.html
MAF, IAT, MAP and Coolant Level Sensor problem all together? http://schematicsdiagram.blogspot.com/2011/12/maf-iat-map-and-coolant-level-sensor.html
Engine Coolant Temperature (ECT) Sensor Replacing? http://schematicsdiagram.blogspot.com/2011/12/gmc-engine-coolant-temperature-ect.html Loosing Coolant? http://whoisbyme.blogspot.in/2012/06/loosing-coolant.html
---------- Coolant temperature sensor dies again and again?
http://schematicsdiagram.blogspot.com/2012/01/coolant-temperature-sensor-dies-again.html
----------- Where to Add Coolant? http://repairhelpcenter.blogspot.in/2012/06/2000-daewoo-lanos-where-to-add-coolant.html
------------ Blue Water Warning Light on Dash? http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
Oct 09, 2012 | 1995 Volkswagen Jetta
WHIRLPOOL AKR 301 IS FLASHING O3 F Fault code
F-03 code indicates a failure with the temperature sensor. The sensor comes into the oven cavity on the back wall and is a little smaller than a pencil.
The most common reason for this error is a wire connection between the sensor and the control board. Try to measure the sensor with ohm meter, an read about 1080 ohms at room temperature if it is good.
Hope this helps.
Jul 20, 2011 | Whirlpool AKZ159IX Oven
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Where to add coolant for radiator on a 95 vw jetta?
Add Coolant to spherical reservoir at right rear of engine compartment as viewed from front. If it is low the coolant gauge flashing light will warn you of a low condition.
Jan 01, 2010 | 1995 Volkswagen Jetta
What causes the F-3 warning to come up during baking.
Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 01, 2009 | Kitchen Ranges
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
Temperature warning light coming on,on a 1992 Volkswagen Golf GTI
The thermostat will show what the guage shows. the seal on the coolent bottle can be checked for tightness. so it could be a faulty sensor?
Apr 28, 2009 | 1992 Volkswagen GTI
Different symbols flashing and bleeping
Check ther coolant level, if this is ok, its possible the sensor on the coolant resevoir faulty. the other warning light sounds like the brake pad warning light. is the warning yellow?
Feb 17, 2009 | 1999 Audi A6
Condensation warning indicator
the dew sensor is already malfunctioning....solution convert or replace the sensor...
Oct 15, 2006 | Panasonic NV-DS27B Mini DV Digital...
Indesit W 123 Front Load Washer Logo
160 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
