Question about Hotpoint Dishwashers
Error code AL03 on fdw 80 dishwasher
Can u advise
  • prydesign Jan 11, 2009
    still waiting for a solution ?
Hi yes i did post a problem on the " let our experts fix your problem for free " section, so how long is it going to take as the machine is still not working ? please advise asap
Posted on Jan 08, 2009
The maximum heating time for the water is 45 minutes; if the correct temperature is not reached within this time, an alarm condition is generated.
Possible causes:
  • Heating element broken
  • Safety thermostat open
  • Wiring interrupted / disconnected
  • NTC sensor faulty / incorrectly positioned / poor thermal contact
Jun 01, 2014 | AEG 18 in. Favorit 64800 Free-standing...
Hi I have a Hotpoint fdw80 witch is displaying an error code AL10. Please can you tell me what this means so I can decide a course of action. Many Thank's Amanda
I found these error codes for the hotpoint fdw80
AL01 - Anti flood switch operated
AL02 - Valve or connections
AL03 - Time out - drain
AL04 - Thermistor (module)
AL05 - Circulation pump
AL06 - Time out - fill
AL07 - Not used
AL08 - Time out - heat
AL09 - Software recogntion error
AL10 - Heating circuit
AL99 - Communications error - connectors, cables etc.
H20 - Time out - fill (taps)
Now looking at AL10 error. Most often it is the heater element which is not effective due to scale formation. Make a solution of white vinegar and water (50:50) pour it onto the base of the dishwasher. Leave overnight and run dishwasher as normal. Somehow the vineger has to reach the heating element which is an inline heater. I am assuming normally you would use the hotwater connection from the kitchen tap.
If this does not help - depends how soon into the cycle you get the error you will have to replace the heater. I think it would look like this.
Feb 01, 2011 | Dishwashers
Error code al03
AL03 indicates a time out on drain fault. Either there is a restriction or blockage on the drain side of the appliance or on the pressure side.If the machine empties ok you need to locate the pressure switch, remove the thin tube and blow back into the sump to try and clear the restriction. If the machine isn't emptying or empties slowly you need to clear the restriction/blockage in the drain hose, pump or sump.
Apr 03, 2010 | Hotpoint Dishwashers
Friend got a hotpoint FDW 80 need to no is it hot water supply or cold?
Connect your dishwasher to the HOT supply line. The most common method is to connect to the hot water supply line in your kitchen. Before running the dishwasher, it is also a good idea to turn your hot water on to allow the water in the line to heat up. This will reduce the time is takes for the dishwasher to heat the water for the wash cycle and cut down on the cost of electricity.
Dec 07, 2009 | Washing Machines
Hotpoint ultima dishwasher fdw 80 will not program comes up DEMO tried switching off at mains to try to reprogram all to no avail any ideas gratefully received
i connected to hotpoint dishwasher manuals and it came up with my model and how to rectify the problem which following the instructions i solved the problem .
Aug 07, 2009 | Hotpoint Dishwashers
Ariston Dishwasher LD87, error code AL03
for code al03 ,today i resolve the problem it was a pomp like everywhere in sites riding. we open a popm and there have a black lastic and it was inside of the pipe ,so we take it litl bit out and dishwasher work perfect !! it is easy ! dont be afraid to fix it alone .Just be carefull with a lot of water will come out from the pipes. and sore has to be away from electicity)good luck !
Apr 11, 2009 | Ariston Technologies Dishwashers
Ariston Dishwacher error message
I found a very good page for this problem on the internet - -
After reading that page, I knew exactly what to do. In my case, something had stopped the pump from working, So I could solve the problem without removing the pump.
Mar 21, 2009 | Ariston Technologies Dishwashers
Fault Code AL03 in an FDW80 dishwasher
Al03 stands for problems with the drainage either ur pump is blocked or has just stopped working so not enough pressure to drain out water during cycle
Jan 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW 85 Dishwasher
You just need to switch the machine off for approx 30 seconds from the mains and switch it back on again!!
AL99 means that there is a communication error within the machines software.
Jun 15, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw 85
This is going to keep breaking down,Call the manufacturer and demand a refund.
Oct 03, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
192 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
