Question about Braun Tassimo Espresso Machine/Coffee Maker
NOT SO GREAT COFFEE GROUNDS!
My tassimo leaks and I end up having a cup full of coffee grounds.Out of 9 t disks I have had 4 good cups of coffee,I'm ready to bring out the old coffee maker.HELP PLEASE.
  • 1 more comment
  • vikki_123 Jan 22, 2009
    I am having the same problem. i got it at christmas and has been fine until this week. Has any one fixed this problem??
  • Anonymous Jan 30, 2009
    I have the same problem, but only with Kenco Medium Roast disks. I'm beginning to think Kenco have a problem manufacturing their disks - somehow the grounds are leaking past the filter paper in the disk.
  • Anonymous Feb 28, 2009
    Brand new Tassimo Bosch machine....80% of coffee or tea grounds end up in cup..... they said it was soft water and I need to go and buy water for the machine.... you must be kidding. so much for convenience
  • 3 Answers
Might there be some stuff crusting the dispanser vent? Did you clean it regularly? If you've not done that, this is what you do:
1) Open up the lid where the T-Disc is supposed to go.
2) Take out any moveable (not breakable) object, for instance the thing that punctuates the T-Disc(its made of two parts stuck together) and the T-Disc holder.
3) Take 'em apart and put 'em into your dishwasher or wash it by hand.
4) Wipe the entire T-disc area with a damp cloth, make sure nothing stays there that isn't supposed to be there.
5) Put the removed and cleaned parts back very carefully and watch out that they are exactly in place, if in doubt wheter they are fitted correctly, just shake them a little. There should be no movement other than up and down.
6) Enjoy your coffee!
Posted on Jan 23, 2009
Bosch Tassimo TAS4513UC 1-Cup Coffee Maker manual
I looked up your problem and found the same one was answered previously on fixya. I have copied and pasted the previous answer here for you. Good luck and I hope you have a great day!
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Mar 25, 2014 | Bosch Tassimo TAS4513UC 1-Cup Coffee Maker
Coffee overflows and grounds sit on top of pod
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
How much coffe grounds do I need to put in for 36 cups of coffee
2 cups of coffee grounds for 36 cups of water.
Your manual is free to download here. Page 4 lists combinations of coffee grounds and water for coffee.
I hope this helps & good luck! Please rate my reply. Thank you..
Mar 24, 2011 | West Bend (58036) 36-Cup Coffee Maker
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
How much coffee grounds should I use for 30 cups of coffee made in a west bend 30 cup coffee maker?
!/4 cup of coffee for every 8 cups of water or almost a full cup of coffe for your 30 cup pot...
heatman101
Sep 07, 2010 | Microwave Ovens
Coffee grounds in cup w/ Keurig 60
I have the answer because it is happening to me now. Moreso with the Timmothy's brand K cups. I did a little forensics on a good brew, and then on two slow with grounds in the final brewed coffee.
The inner filter is placed in the k cup and it is not glued to the top rim. The bag then just sits on the bottom of the k cup as it is passed with the hot pressurized water.
The good cups are glued to the top rim and there is no problem.
To investigate....remove the foil top carefully after the cup cools. Rinse out the grounds, and the filter bag should still be glued to the rim. if you've got a dribbler and one that passes the grounds into the cup...you will find the filter bag had fallen loose from the rim. Manufacturer defect...You bet!!!
I had 8 from a box of Timmothys 25 count pass grounds. Green mountain coffee may once in a while pass grounds, but very rare and maybe three times in the 4,000 k-cups we've used.
Mar 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
How much coffee grounds for a 22 cup west bend coffee maker?
We use 2 1/4 cups for a full 36 cups. A fraction under 1 1/2 cups is good for 22 cups.
Nov 26, 2009 | West Bend (58036) 36-Cup Coffee Maker
Amount of coffee to use
This is from the FAQ section of West Bend's website at www.focuselectrics.com:
As a guideline, use the following amounts of ground coffee for the number of cups being prepared. Use standard measuring cups ( as used to measure flour, sugar, etc.) to measure the coffee. The amounts of coffee below will brew mild to medium strength coffee which most people prefer. The amount of coffee can be adjusted to suit personal preference. As a guide, there are about 5 cups of coffee to a pound (16 ounces).
  • 12 - 18 Cups Coffee = 1 - 1 1/4 Cups Grounds
  • 20 - 25 Cups Coffee = 1 1/4 - 1 1/2 Cups Grounds
  • 28 - 36 Cups Coffee = 1 1/2 - 2 Cups Grounds
  • 40 - 45 Cups Coffee = 2 - 2 1/2 Cups Grounds
  • 50 - 60 Cups Coffee = 3 - 4 Cups Grounds
  • 70 - 80 Cups Coffee = 4 1/2 - 5 Cups Grounds
  • 90 - 100 Cups Coffee = 5 1/2 - 6 1/4 Cups Grounds
  • Hope this helps. You might also be able to download the manual from there if you look for your model.
    Sep 23, 2008 | West Bend 13500 Coffee Maker
    Braun Tassimo Espresso Machine/Coffee Maker Logo
    849 people viewed this question
    Top Braun Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
