Question about Vtech i5807 (735078006394) Cordless Expansion Handset
Hard to press keys on i5807 vtech phones
I have a base phone i5867 and an expansion unit i5807 they are now more than 2 years old. I am highly satisfied with their performance in all aspects except both the handset keypad have started troubling as it has become contantly hard to press certain keys like # 8, 4 & 1. sometimes i have to press them 4 to 5 times. I thought there might be some dust which might have been collected underneath the pad so i tried to open and clean it. I could find 4 screws at the battery compartment but still could not open it. I don't want to force and break it as i love these phones. I shall be really thankful if someone can help me figure out how to fix it.
Thanks in advance.
  • 89 Answers
Your best bet is to get new handsets
Posted on Jan 07, 2009
Bought a used vtech 5.8 phone, charged the battery and now see message "not registered. I can not make calls... how do I register it?
I believe it is telling you it is not registered with the Base Unit. You did get the Base Unit with it didn't you, otherwise you have a paperweight.
If you do have a set then this is the answer
Tip 1 of 1
Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger.
Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while, the handset will emit a series of tones, and the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
https://vt.vtp-media.com/ecp/documents/product_Product/67/UserManual/1647/ia5874_manual_bkm.pdf
Search Results
VTech 5.8GHz Cordless Home Telephones & Handsets ' eBay
https://www.ebay.ca > ... > VTech 5.8GHz Cordless Home Telephones & Handsets Results 1 - 25 of 151 - This is a Vtech 5.8 cordless phone digital answering machine base with time stamp & a handset that needs a new battery. It came from an ...
Technical Product Support ' VTech® Cordless Phones
https://www.vtechphones.com/support/technical-support Stay up-to-date on new VTech products, emerging technology and special offers. ... My VTech DS6722-3 Cordless Phone rings once and then disconnects. Why ...
Vtech 5.8 Phone Instructions ' Techwalla.com
https://www.techwalla.com/articles/vtech-58-phone-instructions Mar 31, 2015 - The Vtech 5.8 is a cordless phone that allows you to add additional handsets to your main phone so that you can have quick access to phones ...
[PDF]User's manual - VTech Canada
www.vtechcanada.com/support_docs/vtt/CS/CS5111-x_en_cib.pdf everything new at VTech, visit our website at www.vtechphones.com. ..... Once you have initiated your call by dialing the phone number in pulse (rotary), press.
[PDF]User's Manual
https://vt.vtp-media.com/ecp/documents/product.../67/.../ia5874_manual_bkm.pdf and operate your new VTech phone . Please take the ... Enhanced 5.8GHz Technology - Dual band transmission combines the best of 5 .8GHz and 900MHz ...
Video as well in link
vtech 5 8 phone Google Search
Jul 17, 2017 | Vtech Lands Phones
Phone are 5.8 ghz vtech
may be the frequency problem for noise problem.
pleaSE CHECK IT OUT.
ADJUST THEM AT SOME PROPER LEVEL..
AND THEN TRY.
Oct 18, 2008 | Vtech 5.8 Ghz Handset Cordless Phone...
How do you keep Base Unit of Vtech phone clean
Hello! Go to;
www.puremobile.com/vtech-cordless-phones.asp
This company offers a large selection of screen protectors ; Although none that are specific for your phone. Find a product that is close in size and trim to fit.
Guru.................saailer
Jan 06, 2010 | Vtech Digital Cordless Telephone VT-2568
VTech 2420 handset will not promp me to key in the base ID
If the other three handsets work ok then you have a defective handset.
Mar 17, 2017 | Vtech VT 40-2420 Cordless Expansion...
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
Can't Connect Displayed
CAN’T CONNECT
1.Displays when one handset is on a call and the other handset presses PHONE.
2.Displays when base power is off and PHONE is pressed.You’ll
also hear a sad tone.
3.Displays when an out-of-range dial fails to connect.
RINGER OFF
The handset
THIS IS SECTION OF MANUAL. MAKE SURE THE OTHER HANDSET IS NOT ON. PRESS THE OFF KEY JUST IN CASE.
Jan 25, 2008 | Vtech ia5845 Twin Cordless Phone
Phone not connecting
I am having the same problem. Had it last year, too but bought new batteries for all the handsets and that fixed the problem. However, this year I can't find the batteries anywhere!
Jan 23, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Phones cant find base
I have two handsets, one of them recently starting dropping the connection to the base quite regularly [even if it was just inches away], and I ended-up in the same situation after unregistering the phone.
In my case, I was able to remove the battery from the phone [as you did] but also unplug the power on the base unit for several seconds. After restoring power to both, I was able to re-register the handset and it appears to be working more reliably now.
Jun 09, 2007 | Vtech i5871 Cordless Phone
Vtech i5807 (735078006394) Cordless Expansion Handset Logo
141 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
