Question about Sharp XR-10X Multimedia Projector
Replacement of bulb
I cant get the old bulb out of the projector, I removed all the screws but it seems jammed, it wont even budge. what should i do?
  • 2,237 Answers
The heat expands the plastic and wedges it in there pretty good. use a flat-head screwdriver, put it under the lamp handle, and pry it just enough to break it loose, the pull it out!
Posted on Aug 17, 2009
Loose cable vax power 3
Try 'tightening' the screws first even if just a bit. This can possibly break them loose so you can remove them with the normal counter-clockwise motion.
May 26, 2014 | Vacuums
Light bulb replacement
https://www.google.co.uk/search?q=Hitachi+CP-X253+bulb+replacement.
Fourth result.
"User manual" link on that page.
Page 48 of that document.
Turn off projector and remove power, undo screw on cover, take cover off, undo screws on bulb housing, remove bulb, put new bulb in, do screws up, replace cover, do up its screw, reconnect power and turn projector back on. Go into menu, advanced, option, lamp time, and push the up button to reset hours.
I literally just read that out of the manual.
Jan 30, 2014 | Hitachi CP-X253 Projector
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    Replace an existing bulb in an existing bulb cage.
    it's always best not to go with the cheapest price online. you'll have to remove the screws and brackets holding the bell on, and the screw holding the plug on. if the new one didn't come with a plug, remove the plug wires from the old lamp. reverse process to install. but be careful not to overtighten, or you'll crack the bell.
    Feb 02, 2010 | Sharp Notevision PG-C20XU Multimedia...
    I have infocus lp70 model projector. i replaced the bulb and now it won't light. i put back in the old bulb and the light still wont come on...any ideas? You can tell that the projector wants to run and is...
    if you don't hear a high-pitched whir, your colorwheel needs replacing. you can remove the lamp and see the colorwheel inside (colored glass wheel). if you turn it on without the lamp, the colorwheel should still spin. if it does, you have a ballast problem. if not, the colorwheel. you'd still need to send it in to an infocus authorized service center. try av solutions in ny. they're pretty good.
    Oct 22, 2009 | InFocus LP70+ Multimedia Projector
    New bulb in now wont work - no power - wont turn on to reset lamp
    first, make sure you have the correct lamp. the lamp for the xr-10x-l looks like the xr-10x, but the plugs are different (common mistake). make sure you have the AN-XR10L2/1, not the AN-XR10LP/1. to reset the lamp timer (with the projector plugged in but off), hold down the enter, down arrow, and menu buttons and press the power.
    May 30, 2009 | Sharp XR-10X Multimedia Projector
    How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
    remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
    Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
    Cannot remove lamp assembly from Sharp XR-10X projector
    flathead screwdriver under the lamp handle from the front and a sharp push down on the screwdriver handle (but don't break it) will dislodge it. it wedges in there pretty good.
    Mar 27, 2009 | Sharp XR-10X Multimedia Projector
    I cant get the old bulb out of the projector, ive removed all the screws but it wont budge
    You really have to pull on it to get it out, it's really wedged into the housing
    Jan 07, 2009 | Sharp XR-10X Multimedia Projector
    How to replace an hp 070 projector lamp
    undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
    Dec 04, 2007 | Office Equipment & Supplies
    Sharp XR-10X Multimedia Projector Logo
    44 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
