When turn computer on it goes to setup but then the kyboard won't respond won't let me push f1
    Sergeant:
  • 367 Answers
Unplug keyboard in back of computer then replug and reboot the computer. If it is usb Skinny square end try another USB port
Posted on Jan 07, 2009
This problem just started yesterday.When booting up,the first screen with the white bar goes across,then it goes to a black screen and beeps once with the message,hit F1 to reboot or F2 to setup menu,but...
restart your computer press F8 then click restore the directory setting this will restore all the directory in the system and the system will reload properly if this doesn't work you will have to re install the OS
Jun 28, 2011 | Dell OptiPlex GX110 PC Desktop
I m unable to open my bios setup utility, I hav IBM A51 8122 KQP desktop.
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
Notes:
a. If you have a USB keyboard installed on your computer and the Setup Utility does not display using this method, turn on the computer, then immediately press and release the F1 key repeatedly until the Setup Utility displays.
b. If a user password or an administrator password has been set, the Setup Utility program menu is not displayed until you type your password.
I hope this helps.
Mike
Jun 01, 2011 | IBM ThinkCentre A51 PC Desktop
Ok so my netbook goes to a blue screen where it says " press f2 to run setup, press TAB to display BIOS POST message" and stays there. if i push f2 then it goes to a black screen where at the...
Probably the hard drive is dead. Did you drop it recently? Anyway, it could be just the connector, if your good with hardware you could open it and check. I would suggest you to use the warranty though.
Mar 03, 2011 | ASUS Eee PC 1000HE Netbook
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
Computer: dell dimensio c521 problem: when i turn computer it goes to a black screen stating: "diskette drive 0 seek failure" and below it says: "Press F1 to continue, F2 to enter SETUP. i pressed...
Please follow the below stesp:
Enter the setup, and there will be a setting in there somewhere called "Halt On" and if you set that to "No Errors" the computer should boot fine.
This works with Dell computers.
Diskette drive 0 seek failure — See "Drive Problems" in your Owner's Manual.
Apr 01, 2010 | Computers & Internet
Can't get the IBM Think Pad 600E to start.
You need to get into the BIOS setup.
Turn off power to the computer. Wait about 30 seconds. Hold down the F1 key while you turn
on power and keep holding down that key until the setup screen comes up. Go to the network boot section and disable Network Boot. Save setting and restart. That should fix it.
Mar 15, 2009 | IBM Computers & Internet
Wont load anything including bios
Sounds like your operating system has been damaged and no longer works. You will need to reinstall it.
If its xp then u will need to put the hard drive in another pc to back up any data. If its vista then all your old files will be stored in windows.old on the c drive as long as u dont format it during install.
Hope this helps?
Dec 29, 2007 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
