Question about Compaq Evo N610C Notebook
Key board won't respond
When i start computer it goes into setup but keyboard will not respond won't let me push f1
    Scholar:
  • 36 Answers
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
This problem just started yesterday.When booting up,the first screen with the white bar goes across,then it goes to a black screen and beeps once with the message,hit F1 to reboot or F2 to setup menu,but...
restart your computer press F8 then click restore the directory setting this will restore all the directory in the system and the system will reload properly if this doesn't work you will have to re install the OS
Jun 28, 2011 | Dell OptiPlex GX110 PC Desktop
I m unable to open my bios setup utility, I hav IBM A51 8122 KQP desktop.
To start the Setup Utility program, do the following:
1. If your computer is already on when you start this procedure, shut down the operating system and turn off the computer.
2. Press and hold the F1 key then turn on the computer. When you hear multiple beeps, release the F1 key.
Notes:
a. If you have a USB keyboard installed on your computer and the Setup Utility does not display using this method, turn on the computer, then immediately press and release the F1 key repeatedly until the Setup Utility displays.
b. If a user password or an administrator password has been set, the Setup Utility program menu is not displayed until you type your password.
I hope this helps.
Mike
Jun 01, 2011 | IBM ThinkCentre A51 PC Desktop
On the bottom, it shows &lt;esc=boot menu&gt; &lt;f1=setup&gt; &lt;f10=system recovery&gt; but it doesn't respond to anything or move from this screen
Check that your keyboard is connected, and is working properly.
Try your keyboard on a different computer.
Try a different keyboard on your computer.
The 'ESC' key should always work.
The 'F1' key should always work.
If your disk-drive is *NOT* "dead", then the 'F10' key should work.
If neither 'ESC' nor 'F1' work, you have a serious problem with the motherboard.
Feb 03, 2011 | HP Compaq Presario SR1850NX (ER925AA) PC...
I key board is not working and its new
You either have keyboard disable in bios. You should check bios when you boot the computer to see if the keyboard is disable.
Aug 23, 2009 | Dell OptiPlex 360 Desktop Computer
When turn computer on it goes to setup but then the kyboard won't respond won't let me push f1
Unplug keyboard in back of computer then replug and reboot the computer. If it is usb Skinny square end try another USB port
Jan 07, 2009 | Computers & Internet
Acer daulcore processer motherboard model mcp61sm-am
ok fair enough.... boot the computer and watch the screen.... you need to watch for the key to enter setup.... delete key seems to be the most popular but i've had computers use f1 and f2, f11 and f12.... if it goes to fast hit pause as it gets to the point where it tells you the key to hit to enter setup.... after you are in change the boot sequence to boot to cdrom..... hit f10 and save the changes... reboot to the cd and continue with your install
Robert
Sep 03, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
