Question about Dell OptiPlex GX260 PC Desktop
No Video on Boot up
I got this computer with no HD or Memory. I added a 40 gig HD and 512 of the proper memory and went to do a new install of XP. Computer powers and no output from onboard video. Monitor shows no input.
  • brucesheffle Jan 07, 2009
    The memory is installed correctly no beeps
    worked thanks
  • 679 Answers
Check your inboard display card,
plug another display card to your computer and see whats happened.
Posted on Jan 07, 2009
  • rockfixya
    rockfixya Jan 07, 2009
    and also check monitor by using another monitor.
    Thanks for using FixYa.
  • 124 Answers
Your computer should have come with a hdd that had had comp bootup info try to format the drive and install a computer boot if your computer can boot to say press f2 or f12 try to hit f12 and change the boot info to get it to run
    Sergeant:
    Champion:
  • 435 Answers
Hi, Try checking with a different monitor. If still doesnt work, your on-board memory is faulty.
  • Dell Master
  • 4,806 Answers
Hi there
Do you get a post screen at all?
  • Lee Hodgson
    Lee Hodgson Jan 07, 2009
    Hi there
    Even if the memory is faulty you will necessarily beep, all it takes is just one of the address bus contacts to faulty and it will give you no indication that the memory is faulty.
    Motherboards come with at least 2 memory slots, take it out and put it in the other slot, make sure that the slots are free of dust, also make sure that the motherboard supports the bus speed of the memory.
    Turn the machine on, if the monitor comes on then the issue will have been a build up of dust.
    Good luck
  • Dell Master
  • 6,487 Answers
Check first the connection of your monitor to the video card and make sure its properly connected, if still no video output try to reset the BIOS of this computer to set it back to its default settings.....
  • Dell Master
  • 13,433 Answers
Do you hear any beeps? check the memory, reseat it, are the original components functional?
optionally you can try removeing all the ram, start up without ram, and then insert one module back and try again.
note you need to unplug when removing components from inside the computer.
If you hear beeps count the short and long. Thanks.
1 short beep is ALL OK anything else is very likely a error.
    Sergeant:
    Champion:
  • 304 Answers
Try to use a expansion agp video card. better to clear CMOS this will do the trick
    Genius:
  • 1,269 Answers
If you hear 2 long beeps, that's a memory fault. Please reseat your memory by removing it and reinserting it.
  • Michael Galve
    Michael Galve Jan 07, 2009
    The processor needs to be re-seat.Try to disengage the Processor from the motherboard and clean the Processor housing using brush. Look for the BIOS reset jumper on the motherboard and do reset it.
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
Memory upgrade didn't work
You may have to go into your BIOS to get the new memory recognized. However, according to the service manual for your computer (found at this link http://h10032.www1.hp.com/ctg/Manual/c00311113.pdf) you should not have to do this. It says your memory is installed incorrectly or it is the wrong type. Since you've verified the type with the original memory, that should not be the problem. Try removing the modules, use some compressed air and blow out the memory sockets, and re-insert them. It is also possible that static electricity could have claimed one or both. Reinstall the original memory to see if the computer will start back up if all of the above does not work. If the original memory works, return the new memory for an exchange.
Feb 14, 2010 | HP Compaq Presario SR2030NX PC Desktop
Compaq EVO N1020V Not reporting RAM correctly
This sounds as thought he RAM is faulty.
You need to have installed 2 x 512 MB DDR 266 SoDIMMs and not 1 x SoDIMM.
If you have placed 1 x 1Gb SoDIMM in ther EVO this would account for you only seeing 480Mb of RAM.
Sep 24, 2009 | Computers & Internet
Cannot install vista
you need a 40 gig hd. and 512 memory at the minimum to install vista.
Jun 16, 2009 | Acer Aspire M1641-U1521A PC Desktop
My compaq presario sr1230nx crashes after 40 minutes of use to the bluescreen with vista. Has anyone had this happen? I ugraded memory to a gig and a new older nvidia video card. Is it a memory thing, a...
It could be a memory issue as the bare minimum to run Vista is 1 GB. Also make sure all your drivers are up to date with the proper vita drivers. Hope this helps.
Jun 03, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Sep 18, 2008 | Gateway 835GM (835GH) PC Desktop
Memory upgrade for P6VEM3 MB
For this mainboard, you must use 168-pin, 3.3V unbuffered PC100 or PC133 SDRAM memory modules. You can install any size memory module from 32 MB to 512 MB, so the maximum memory size is 2 x 512 MB = 1 GB. As noted on pg. 9 of your manual. Shut down your system. Remove one dimm of memory & start the Pc. Does it boot & do you have video? No? Shut down & replace the the dimm with next stick of memory. Try again. Still no video? Replace memory with old memory. Did you regain video? In most cases of installing new memory it's found the memory just wasn't seated well enough. In few others the memory did not meet the correct voltage.
prazum post back your findings.
Feb 22, 2008 | EliteGroup P6VEM3 Motherboard
512 Mb memory upgrade
well sounds like compatible issue make sure it is ddr,sdr,ddr2 then check the speed and then checkto make sure that it is pushed in all the way in
Oct 18, 2007 | Acer Aspire 3610 Notebook
Memory/Graphic problem
This might have something to do with DVMT or Digital Video Memory Technology. Basically, the amount of video memory is dependent on the amount of memory installed. I'm not very familiar with acer system BIOS but try to look for VIDEO under system BIOS and try to select any fixed video memory if possible. you can also try to disable DVMT.
Sep 30, 2007 | Acer Aspire 3680 Laptop
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
