Question about Frigidaire FRS26ZSG
Freezer leaking water
Water is leaking into the bottom of the freezer which is then turned to ice but will leak out with in a couple of days. Frididaire FRS26ZSG. Not sure what is causing the leaking.
  • 5 more comments
  • Anonymous Jan 28, 2008
    I have the same problem with my Gallery Series FRS26ZGHBO.
  • vvfrig Feb 11, 2008
    Same problem but the ice forms and melts (as aforementioned) even with the icemaker arm in the OFF position-FRS26ZNH side by side
  • Yorey Apr 12, 2008
    My Frigidaire Gallery side by side FRS26ZSH freezer is leaking. I shut off the water supply a month ago. The leak is coming from a vent, inside the bottom back wall of the freezer. A chunk of ice that has formed on the bottom of the freezer is slowly leaking and driving me nuts.
  • jarney Jul 01, 2008
    I am having the same problem. I don't believe that this has anything to do with the icemaker. I think the second solution is the right track. It could be that too much food is blocking the fan behind the bottom tray. I just removed two long loaves of bread that were interfering with the air flow. We will see if that makes any difference
  • JP Savich Jul 03, 2008
    exact same problem with my Frigidaire Gallery side by side FRS26ZSH. I shut
    off the water supply a year ago. The leak is coming from a vent,
    nuts.
    need answer, its taking a toll on my hard wood floor
  • Anonymous Aug 29, 2008
    I have that exact problem, what can I do to fix it w/o calling a reapair specialist. Thanks
  • smh7670 Mar 24, 2009
    I have the exact same problem. Solutions anyone???
Our side by side Frigidaire was doing the same with water dripping out from the bottom of freezer area when the door was opened. It was a clogged drain tube (for the freezer defrost coils) causing our problem. The following steps are how I fixed the clogged drain tube which may be difficult to find and service depending on your unit and experience with appliance repair.
1st, pull frig/freezer away from the wall so you can get behind the unit then UNPLUG the electrical cord. You can leave the water line hooked-up if you have enough room to get behind the unit. Go ahead and round up a flashlight, vacuum, and whatever tool(s) required to remove screws from your unit.
2nd, MAKE SURE IT IS UNPLUGGED, then using whatever tool you need (1/4" socket for some) remove the screws from the paper (or other material) cover located on the back of unit near the bottom. When this cover is removed you should see a fan under the freezer side and a compressor unit under the refrigerator side if you have a frig/freezer with coils located under the unit instead of on the rear.
3rd, you may need to vacuum first to see it but there is a (black, dark grey, or white) drain tube located under the freezer side (near the fan in ours) running down from the freezer compartment to a plastic tray. Ours was approx 1/2" in diameter yours may be the same. Also, the tray may be built into the bottom of the unit and not be removable
4th, when you have located the drain tube you will need to gently pull it up (twisting side to side may help) and out of the retainer built into the tray so you can clean out the end. I used a vacuum and straightened paper clip to remove the crud from the tube and water started coming out while I was doing this. While you have the back/bottom cover off you might as well vacuum everything you can safely reach to help prevent the drain getting clogged again.
5th, after cleaning everything place the drain tube back into the retainer on the plastic tray and make sure you check the tube to prevent a kink. Also, the tube should not touch the bottom of the tray.
6th,replace the back/bottom cover and make sure to use the correct fasteners for whichever hole/clip they were removed from. After the cover is back on plug it back in and listen for the fan to come on. If everything sounds normal push the unit back to its normal position and congratulate your self on a job well done.
Posted on Jul 05, 2010
  • willgraynj Nov 18, 2010
    Excately the problem... fix and back together in 15 mins... thanks!!
This problem is not related to the ice maker or the water line. there is a defrost coil at the bottom, back wall of the freezer. The coil is defrosting the frost on the coil, it runs down the wall to the bottom of the freezer. At the bottom of the freezer it re-freezes. When the ice builds up the water then runs out the bottom of the sill. I have identified the problem but at this time I don't have a solution. I am trying to find out more on the cycle of the defrost / timer.
Posted on Jun 07, 2008
We had the same problem. There is a drain at the bottom of the freezer. It cost us 30 minutes of the guy's time to get the dirty ice out of there.
Posted on Jul 19, 2008
Is is a side by side fridge/freezer? Do you have an in-freezer ice maker, and is it functioning properly? It's water supply line may be the source of the leakage. You might try to determine if the incoming water is : A) missing the fillcup on the icemaker or B) running way too much water and overflowing the ice cube mold (it should only run for 5-10 seconds ). I'm wrestling with the latter (option B) on a KitchenAid side-by-side freezer right now. I used a multimeter to test the ice maker module, and that failed so I'm guessing it will need to be replaced. For the time being, I've closed the valve supplying water to the ice/drinking water dispenser. If you try that (closing the water supply valve) and it solves the probem, then you may have found the culprit. Follow the supply line from the back of the unit to find its source -- the valve may be inline.
Posted on Jun 04, 2007
2 Suggested Answers
SOURCE: Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Posted on Sep 19, 2008
Leaking water on floor
Remove contents from bottom of freezer. Turn ref/freezer off. Use the handle end of a screwdriver and carefully break up the ice build up from the bottom of the freezer. Find the condensate drain and remove ice build up. Find the condensate drain and remove ice or any kind of restriction from the drain line.
Or you can turn the refrigerator off for a day , mop up the water and blow out the condensate drain
Jan 18, 2016 | Maytag Refrigerators
Water leaking into bottom of refrigerator section
Make sure you dry everything in the freezer when you have the door open and remove ice. It won't be a leak it will simply be the warm air inside the freezer that has turned into condensation. Double check the seal around the door to see if it curled up as that could be letting warm in and cold out giving same results.
Mar 02, 2012 | GE Profile PFSS6PKX Bottom Freezer French...
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the styrofoam..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
My Whirlpool has been filling the bottom under the crispers with water and leaking out the vents (?) from the freezer down into the fridge compartment. I finally caught it today being rather loud, probably in a defrost cycle, and it was positively POURING in the fridge. After some more research on this site I removed the freezer bottom tray (1/4" ratchet needed) and found a layer of 1/2" thick ice under the tray. My guess is the drain hole iced up. Removed all the ice from under the tray and on the metal drain run in the back (danger, seemed sharp) and put it all back together. I didn't try to pour hot water down the drain yet, thinking positive thoughts that the drain itself isn't iced all the way to the tray near the floor. Will watch it carefully.
Apr 20, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
The icemaker leaks water from the fill tube into the fridge
my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerator leaks water
most likely you have a plugged drain int he freezer compartment. if yo will look under and behind the lower basket in your freezer you will most likely see a bunch of ice build up. clear this ice out then you will see a drain hole in the center section behind the metal cover in the rear try to get some hot water into this hole to clear ice and to clear the drain then u shoul be good to go. thanks for using Fix Ya Peyton
Feb 18, 2009 | Whirlpool GS6NBEXR Side by Side...
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
Refrigerators Logo
8,848 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
