Question about Sharp XR-10X Multimedia Projector
I cant get the old bulb out of the projector, ive removed all the screws but it wont budge
First, make sure you have unscrewed both screws holding the bulb assembly in place. Then, there is a power connector that is very tightly connected to the case. That's what's preventing you from sliding the bulb assembly out easily. Notice the dark gray "handle" across the middle of the top of the bulb assembly. If you stick a butter knife up under that dark gray plastic "handle," you can pry the assembly up and out. If your bulb is definitely blown, then don't worry about using too much force to pry that thing out. It's not connected to anything else. If you're not sure the bulb is blown, then be sure to leverage the butter knife against the case to gently pop the assembly out of the case.
Posted on Jan 17, 2009
You really have to pull on it to get it out, it's really wedged into the housing
Posted on Jan 12, 2009
I cant unscrew those little screws in the bottom of my iphone 3GS! ive tried the smallest screwdriver i have, and sharp knives.. why wont they budge!!!
You normally need special screwdrivers, apple have a habit of replacing normal screws with special 'Flower' screws. You should have a look on ebay, normally you can buy the right screwdriver for about £3, the only issue with this is opening an iPhone invalidates any warranty and they can tell...
Feb 03, 2011 | Cell Phones
Ive just bought a new bulb for my projector (Optoma HD700X DLP Projector), taken the old one out and screwed this one in, but im still getting a read light when i turn it on, it sounds like it is...
Hello
if replacement lamp has done, was the lamp timer reset after replacement? and if the lamp is original, there is either a bad lamp or a cooling problem.
Good luck
Dec 14, 2010 | Optoma HD700X DLP Projector
I have a 1992 for explorer sport and cant get the front passenger seatbelt to come out. its stuck all the way in. ive tried to pull it out and it wont come it wont even budge a little. ive looked at the...
The plastic cover should be able to be removed. There is a ratchet mechanism for the seat belt, after removing the cover, you maybe able to free it up to get the belt loose, some WD-40 may help.
Apr 28, 2010 | 1992 Ford Explorer
Ive been trying to change my headlight buls on my 04 eclipse gts. im trying to pull out the power connector like everyone says. but the dang thing just wont pop out!!! ive yanked on it tryed doing slowly....
Did you remove the cap that covers the bulb socket? There will either be a plastic cap that twists or a rubbery dust cap that the wires go thru. IF you have the cap, twist it 1/4 turn counterclockwise and pull it back. IF you have the dust cover, squeeze and get it out of the way. If your bulbs have a number like 9005 or 9004 you should be able to unplug the old one (may have to release the clip with SLIGHT pressure from a screwdriver). If the bulb number is like H3 or H7, or if you have the rubber cap there is most likely a clip that looks like a bent paperclip with a screw at each end.--You have to get that out of the way-it holds the bulb in the light.
Mar 14, 2010 | 2004 Mitsubishi Eclipse
Can't remove dash from 1990 toyota celica to replace dash bulbs
hi i had d same problem with my gt4,i lightly wedged a piece of hard plastic between any gap n popped open the clips,be careful tho
Jun 24, 2009 | 1990 Toyota Celica
How do i change the bulb in a sanyo pro xtrax multiverse plc-xu30 prodjector
remove the screw on the door on the bottom of the projector for the lamp and pull out the old bulb and replace
Apr 16, 2009 | Sanyo PLC XU30 Multimedia Projector
Cannot remove lamp assembly from Sharp XR-10X projector
flathead screwdriver under the lamp handle from the front and a sharp push down on the screwdriver handle (but don't break it) will dislodge it. it wedges in there pretty good.
Mar 27, 2009 | Sharp XR-10X Multimedia Projector
Replacement of bulb
the heat expands the plastic and wedges it in there pretty good. use a flat-head screwdriver, put it under the lamp handle, and pry it just enough to break it loose, the pull it out!
Jan 07, 2009 | Sharp XR-10X Multimedia Projector
Trying to change LG side-by-side fridge filter
try removing hte kick plate first. and slightly push in as you turn counter clockwise 90 degrees. it'll come. ive hadsome stick but never break on me
Mar 12, 2008 | LG LRSC21935 Side by Side Refrigerator
How to replace an hp 070 projector lamp
undo the top cover you will see a black cover with clips and at the back or side there are two small screws which hold the rear concave mirror in place undo the screws bend the clip back gently and remove ....pop out old bulb and put in new bulb with a piece of tissue dont touch it with your fingers.... do all the rest in reverse order ...did mine tonight took 10 minutes just a bit tricky getting screws back in.....you need a long magnetic posidrive with a small head....
Dec 04, 2007 | Office Equipment & Supplies
Sharp XR-10X Multimedia Projector Logo
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
