Question about Verge VGA285 Car Audio Amplifier
Protect Light On Subwoofer Cuts Out
I recently got a new car and moved my system from my old car, I hooked it all up and everything was working fine. Two days later the 20 amp fuse on the power wire blew so I put in another fuse, Now it just cuts the sub off, it will turn on for a second or two then it just cuts off. I turned the gain all the way down then it works but not loud enough for anyone to hear it unless you have the trunk open and your head in the trunk...lol If anyone can help, Thanks in advance! - Vince
    President:
  • 3,130 Answers
If the amp stays on with the input turned down, I would check or have the sub woofer checked speaker for resistance and impedence to make sure that the speaker is not damaged. If you take off the speaker and turn up the amp and it still cuts off, there is a problem in the amp itself. Most likely a problem in the differental circuit of the amp. Have a pro take a look and bench test the amp. GOO LUCK
Posted on May 31, 2007
  • 883 Answers
Some type of over-current protect device in sub amp section gone bad..perhaps a board-mounted resettable circuit breaker or fuse has gone bad? these are hard to locate on the board for a novice.
Posted on May 30, 2007
Why want my subwoofer play like it's supposed to? It barely plays
check your ohm load on that audiobahn sub some amps run at an bypass or ohm load and then kick off if its the sub itself is not a 2ohm stable or 4ohm stable
Mar 03, 2010 | Car Audio & Video
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
S series sub cuts out
this sounds like an ohm load problem do u have it bridged
Nov 01, 2009 | Alpine SWR-1222D 12" Type-R Series...
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Intermittent Subwoofer
the wire from the coil to post is probably severed.you might have to take the dust cap off..
http://www.mwaspeakerparts.com/
this is a speaker part site
Jan 13, 2008 | Kicker CVR12 Car Subwoofer
Car Audio Problems-Amp cuts out
No the reson for the amp overheating is do to the OHM ratting that you have the sub if to have the both wired up then just wire  one up and that will give you the OHM ratting that your amp is ratted for the way that you might have it is the way that we wire them for coms. where it is on for 30sec and no more. if you would like more help let me know.
Gennisthgreat2000@yahoo.com
Oct 20, 2007 | Car Audio & Video
Subwoofer problems
What started smoking the Sub or the amp?
Oct 08, 2007 | Car Audio & Video
SubWoofer
Sounds like your original and this sub have bad amps. The amp for the sub is not the same as the amp for the other speakers. The old unit has a dead amp and this new one is on the way out. (Pulling too much current on high bass)
Mar 30, 2007 | JVC TH-M505 System
Subwoofer won't turn on
try and see if it as internal fuse ? if not the bad news is that possibly the amp as gone
Jan 01, 2007 | JVC TH-M303 System
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Verge VGA285 Car Audio Amplifier Logo
198 people viewed this question
Top Verge Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Verge Car Audio and Video Expert? Answer questions, earn points and help others
