My bosch washing machine is only part filling with water,not enough to wash. thanks, terry.
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Your pressure switch may be malfunctioning as well.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Bosch maxx 1000
The fill valve may be clogged or defective
Oct 14, 2017 | Bosch Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
I have a bosch nexxt series washer, it seems not to fill with enough water to wash efficiently.
check a water level sensor.open the top on the right side top senzor is konekt with pipe from the tank
Aug 16, 2011 | Bosch Washing Machines
Hi we have a Bosch classic 1000 wfl2062gb. it refuses to wash or spin. the pump is clear and there is no water in machine. motor connections and belt are all ok. running out of ideas.... any suggestions...
Bosch classic 1000 wfl2062gb This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Dec 21, 2010 | Bosch Washing Machines
Water is no fill in mashine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing machine filling with water when switched off
You need to replace the cold inlet valve as it is sticking.
Please rate my solution.
Thanks.
May 13, 2009 | Bosch Washing Machines
Bad bosch
The grey sludge may be due to incorrect soap powder (use only front loader) or excessive powder use. Minimise the powder use and insure you do a very hot wash once every 4 weeks to break down powder that may be building up.
Regards Sam
Apr 15, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Classixx 1000 Express washing machine won't fill with water
cheak the filter witch is at the intake and if when it is going to fill does it buzz if dose that means the vale is working if not call a repaire man out hope this helps
Jan 22, 2009 | Bosch Classixx WVF 2402 Front Load...
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
