Question about NorStar M7310 Corded Phone
Answering calls How do I program the answering options so that when the phone is ringing I can just pick up the receiver? As it stands now, i have to pick up the receiver then push the line I want to answer. All my other phones (same model) answer the line automatically when you lift the receiver.
  • lfournier Jan 07, 2009
    Sending me the link to the manual is NOT helpful! I'm not stupid, I have looked through every manual available online! It is not in any of them- which is why I came here. Help!
  • 2,692 Answers
Why can't I answer a call on line 2?
Confirm the extension # you are working with and that the line 2 key is line 2. do this by pressing feature *0 and the pressing the intercom key, observe the display and then press line 2 key and view display. then go back in the programming and view line 2 apear&ring, change it until it is apear&ring, then release and check for working again. If this dont work check to see if line 2 is programmed as a private line.
Jun 17, 2015 | NorStar T7316E Corded Phone
You need to program the internal voice mail to pick up calls after 6 rings , or program your answering machine to pick up sooner, perhaps 3 or 4 rings.
Mar 02, 2015 | Panasonic KX TG4021 Cordless Phone
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
Answering machine is not answering the phone calls. Have ringer set for 4 rings but the machine never picks up. was working fine until our power was off one day
If your phone rings normally and your can make and receive calls, the line is OK, please check if answering option is on, typically a botton marked ANS or similar with an indicator or a display showing that it's on.
Mar 05, 2011 | Uniden DXA15588-2 Twin Cordless Phone
My phone rings a half a ring then stops. The
you more than likely have "short rings" turned on, in the options of that phone. you'll have to go into the options menu, and look for setting that pertain to ringing and / or rings or ring length.....DON'T change DTMF tones though, that'll get annoying, as thats what you hear when you are calling someone else. hope this helps.
Sep 21, 2009 | Panasonic KX-T7633 Corded Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    The fax picks up every call
    Most fax machines are set-up to pick up all calls. There isn't a way to know you are receiving a voice call until the fax picks up and doesn't hear the tracer signal that kills our human ears.
    You could change the number of rings it takes the fax machine to pickup the call. If you set it to the max, you would have plenty of time to pick-up. this option is normally part of the settings on the machine itself.
    The only other options are to unplug the fax when you aren't expecting to receive a message, or get a dedicated fax line. It depends on how much you use the fax.
    Hope this helps! Please don't forget to rate the answer!
    Jan 02, 2009 | Lexmark X7170 All-In-One InkJet Printer
    Canon MP530 receive fax issues
    Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
    1. Press the <FAX> button to enter Fax mode.
    2. Press <Menu>.
    3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
    4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
    Types of receive mode
    Select the receive mode according to your needs.
    Receive mode
    FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
    FAX :
    The machine does not ring but will receive the fax automatically. Voice call :
    The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
    • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
    • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
    • The phone attached to the machine may not ring depending on the telephone type you are using.
    FAX only
    FAX * :
    The telephone does not ring. The machine will receive the fax automatically. Voice call :
    You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
    FAX :
    Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
    Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
    Manual RX
    FAX :
    The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
    The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
    Ans. machine connect
    FAX :
    First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
    The answering machine connected to your machine will respond to an incoming call. Note:
    • Set the answering machine to answer on the first or second ring.
    • The entire message should be no longer than 15
    Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
    Receiver dosen't pick up line that is ringing
    go to programming section 5
    You want Automatic Line Selection
    Press feature00
    left intercom button press twice (system program)
    press right intercom once (central tel program)
    enter # of extension to be programmed (intercom #)
    press **
    press line buttons in desired order line1 line 2 etc and
    end with left intercom then press**
    enter feature 00 to exit programming
    Aug 26, 2008 | Avaya Corded Phone avaparp18d
    NorStar M7310 Corded Phone Logo
    193 people viewed this question
    Top NorStar Lands Phones Experts
    Oloyede Monsuru
    Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
