Question about Connex 3300 240-Channels Base CB Radio
Standard Microphone Wiring
Could someone please tell me the proper color combination and wiring pattern for a standard hand held microphone for this particular radio? (Connex 3300 240 channel export radio.)
  • el sordo May 13, 2008
    need to know how to wire the 4 pin mic for my ft-101e
  • ky coalminer Mar 15, 2009
    i need to know how to wire a cobra hand mic to this radio the wire colors are the same except the black this mic has a blue wire in it
    Problem Solver:
  • 19 Answers
Pin 1 is Shield(most mics this wire is bare copper) Pin 2 is Audio wire(most mics this wire is white) Pin 3 is Transmit(most mics this wire is red) Pin 4 is receive(most mics this wire is black)
Posted on Aug 01, 2007
SOURCE:
I stopped into a Radio shop and ask them for a power cord for my connex 4600 and he asked me what kind of truck I’m putting this radio in I told him a freightliner he said the connex 4600 Is the wrong...
many trucks have a ground wire in the harness as the cabins are fibre glass or not grounded around the cabin mounts If the radio grounds out through the frame , then there would be no ground for the radio or the aerial wire
to fit this particular may require such a wire in the harness for the radio which it probably doesn't have
As you have been alerted to a problem, it would be advisable to talk with professional radio fitters who work on trucks to get the correct advice before starting on the job
it could save a lot of frustration
Nov 23, 2017 | Connex Radio Communications
How to wire a 4 pin ProComm microphone to work on a 5 pin microphone for a Uniden Grant XL
The simplest way is to order a microphone adapter from ebay or a reputable CB shop. I have all my mics wired for standard 4 pin cobra. The standard 4 pin cobra is the most common and if you keep adapters handy then you can use all different kinds of mics on different radios.
Apr 09, 2016 | Uniden Radio Communications
Color wiring code
what radio?1 shield 2 audio 3 TX 4 RX
Apr 05, 2013 | Cobra HG-M73 Standard 4-pin Microphone
I need a wiring digram for a rk 56 inside the mike my wires are broke need to know were to put them back connex 3300hp
  • With the switch sitting as it is in the picture below (actual switch recessed tho the right. Soldier the wires in this order.
  1. Black
  2. Red
  3. Lite Blue.
  4. Dark Yellow (This yellow wire comes from the mic cord itself)
  5. Shield.
  6. Lite Yellow. (This yellow wire runs off to the side of the mike to the electrical components inside the mic)
  • Standard 4 pin Cobra mic tip to run it to that Connex.
  • Pin 1 - Shield.
  • Pin 2 - White.
  • Pin 3 - Red.
  • Pin 4 - Black.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 05, 2011 | Connex 3300 240-Channels Base CB Radio
Could you please tell me what COLORS that i need to put where when wiring a Superstar DM 452 to a Galaxy Saturn base station radio?
Don't worry about colors. look a the mic switch connections. one wire will be a common ground for TX & RX the middle wire would be ground(pin1) the n/c side will be RX pin4 the N/O side will be TX.... the same for the audio element side, one will be ground and the other will be audio pin 2.. this works for any mic and any radio.
pin1 ground pin 2 audio, pin 3 TX, pin4 RX.. standard pin outs cobra / galaxy/connex exports
Feb 26, 2011 | Radio Communications
Have a Shure SLX Wireless System. The only way the microphone SLX1 or SLX2 is if they are right up to your mouth. If you put the lapel mic on a persons tie you can't hear them. The transmitter is set to...
The Shure SLX2 hand-held microphone has similar performance characteristics to the much-loved (cabled) Shure SM58 vocal microphone. It has a 'cardoid pick-up pattern' intended for close work - being spoken / sung straight into the top of the capsule at no more than about 8 inches from the mouth of the user- to minimise feedback and extraneous noise. If you double the distance between the mouth and microphone the sound level will drop four-fold so distance really matters.
The SLX1 lapel/ lavalier is a semi 'omni-directiona'l pick up pattern microphone, which should work satisfactorily up to 12 inches from the speakers mouth, but closer is better. Always try to get your users to hang it about 6 inches below their chin, at most, and preferably with the top of the microphone capsule pointed upwards towards the mouth.
Here are a few other things for you to try:
  1. There is a volume (gain) knob on the back panel of the SLX receiver unit. Try turning this up to maximum (needs a small screwdriver)
  2. Make sure that both aerials on the receiver are fully extended at different angles to each other and in a clear 'line-of'sight' with the transmitter pack, with no large bits of metal in between which could block the signal. Ideally the receiver should not be more than 25metres from the transmitter. If distance is a problem locate the receiver near to the transmitter and run a balanced (xlr) cable to your mixer/ amplifier.
  3. The angle that the receiver aerials are at should be broadly similar to the angle that the transmitter antenna is at to optimise signal reception.
  4. Make sure the receiver is not located too close to other electrical equipment which may be interfering with the signal (especially voltage transformers, CD or DVD players and hearing loop induction amplifiers which have a strong magnetic field)
  5. Always use good quality batteries - Duracell Ultra or equivalent ( do not use rechargeable batteries as they seldom achieve optimum voltage)
  6. Check that the antenna is tightly screwed into the SLX1 transmitter pack and not damaged.
  7. The SLX2 hand-held microphone has an adjustable level switch inside the body - unscrew the top of the microphone to access it - switch to maximum.
  8. Another possible cause could be an impedance mis-match between the SLX receiver and your amplifier or mixer. There are two outputs on the rear panel of the receiver. One is an XLR (large 3 pin socket) this is LOW impedance and needs connecting to a low impedance input on your mixer/amplifier. You should normally be using this output even if your amplifier has a jack-socket input (use a proper balanced XLR to 6mm trs jack cable rather than a adapter plug). The other output on the receiver unit is a 6mm HIGH impedance, unbalanced, standard jack socket (labelled 'line in'). This would normally be to connect to a guitar amplifier which has a high impedance 'line level' input socket. If you are using this output you may need to use a pre-amplifier to get a big enough signal for a microphone.
You can find the Shure SLX user manual here http://www.shure.com/idc/groups/public/documents/webcontent/us_pro_slx_en_ug.pdf
Jan 27, 2011 | Shure SLX1 Body-Pack Transmitter for...
Its a mk1 148 i have just bought it and need to know how to colour wire a standard k40 mike in as in wich wires where.not much experience.a picture would be helpfull
no need colors. look at the switch and plug to verify them. on 4pin cobras/galaxy/connex radios
pin 1 ground
pin 2 audio
pin 3 TX
pin 4 RX cobras
Dec 09, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
767 people viewed this question
Top Connex Radio Communications Experts
Chris
Damon Nesselrodt
Damon Nesselrodt
Ray Murphy
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
