Question about Polaroid 4226TLMB 42 in. LCD TV
Polaroid TV Code
I need the TV Code for Directv for my Polaroid 10" Under-the-Cabinet TV with DVD Player
  • Anonymous Feb 23, 2009
    none control remote generic response well
    Novelist:
    Scholar:
  • 67 Answers
About the only thing you can do is do a code search. If it doesn't show up then, the remote does not have it (as with most tv/dvd or tv/vcr combos).
Turn the TV on manually. Then, push the switch at the top to the far right (to the TV position). Simultaneously press and hold the MUTE and SELECT buttons until the TV light at the top flashes. Release the buttons, then press and release 9, 9, 1. The TV button should flash again.
Press and release the 1 button again, then press and release the TV POWER button. Press and release the Channel UP button about once a second until the TV turns itself off. Press and release the select button, and you should be good to go.
If after a while, the TV button starts flashing rapidly, then there are no more codes to search, and the remote does not have the code, and you are stuck using 2 remotes..
Hope this helps...
Posted on Jan 07, 2009
I need A DirecTV Remote Code for the Magnavox DV200MW8 DVD Player VCR Combo
Magnavox is the problem. You won't find a code for that :( 10 years of trying and experience!
Feb 23, 2014 | Magnavox DV200MW8 DVD Player VCR Combo
Tip
Polaroid TV DVD Combo Remote Codes Can't find a code to program your universal...
Can't find a code to program your universal remote to control your Polaroid HDTV / DVD combo? Can't find a listing for Polaroid DVD in your remote control code list?
Many manufacturers recycle remote control codes, so often the best solution is to use the code search function of your universal remote.
Here are some remote control codes that have worked to control Polaroid HDTVs:
  1. My 19" w/DVD uses the following Mitsubishi code: 10178
  2. Dish Network remotes: 627, 659, or 688
  3. DirecTV RC64 remote control revealed a code of 10835. This means that 10835, 0835, 835 or some variant many work with many programmable remote controls. On my DirecTV DVR system, this was indicated as a Moxell and/or Motorola TV code.
  4. Use the mitsubshi tv codes they worked for me.
  5. Try Element codes if they are listed in your remote code list.
I hope that helps.
_____________________________________________
Polaroid HDTV Manual Download
Polaroid HDTV Service Manual Download
on May 02, 2010 | Televison & Video
Tip
Polaroid HDTV Remote Control Codes
Polaroid HDTV Remote Codes
Can't find a code to program your universal remote to control your Polaroid HDTV? Can't find a listing for Polaroid in your remote control code list?
I hope that helps.
How to open beltek tv service codes
sir i want the service code of beltek colour tv
Feb 01, 2013 | Polaroid FDM-1000A 10" Under-the-Cabinet...
I need a code for hooking up a polaroid dvd player
You need the right tv remote code. Try to ger the code here
polaroid tv codes
May 25, 2010 | Symphonic ST420FF 20" TV
Tip
Polaroid DVD Combo Remote Codes Can't find a code to program your universal...
I hope that helps.
on May 01, 2010 | Televison & Video
Tip
Polaroid HDTV Remote Codes Here are some remote control codes that have worked...
I hope that helps.
The picture is faded
check the user manual also can be misconfigured or check the video input and the same display
Sep 09, 2009 | Polaroid FDM-1000A 10" Under-the-Cabinet...
Directv remote
1) Use 2 new AA batteries in RC32 remote control;
2) Slide mode switch to "TV";
3) Press and hold the MUTE and SELECT keys at the same
time until the green light under the selected switch
position flashes twice, then release both keys.
4) Enter 9-9-1-1.
5) Press PWR button on TV.
6) Point the remote at the TV and press CHAN+. Repeatedly press CHAN+ until the TV turns off. Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7) Use the CHAN- key to step back a code.
8) When the TV turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the TV remote control.
9) To verify the code, slide the MODE switch to the appropriate position.
10) Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
11) Enter 9-9-0. (The green light under the selected
switch position flashes twice.)
12) To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down in the TV owner manual.
13) Press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.
To control TV volume from Directv RC32:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Feb 11, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid 4226TLMB 42 in. LCD TV Logo
158 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
