I have a cobra 360 laser esd 9190 is there a way to down load a manual"?
SOURCE: laser alert
This is caused by electrical noise in your car's electrical system. Specifically, the problem is excessive alternator whine. This can be exacerbated by somewhat corroded contacts in your car's cigarette lighter socket or by a somewhat corroded vehicle wiring connection to the back side of the cigarette lighter socket.
One potential solution is to try a snap-on RF filter which is available at your local Radio Shack. You would snap this filter around the positive 12V wire leading to your car's cigarette lighter socket. Preferably, if there is enough free slack in the 12V wire leading to the cigarette lighter socket, you would wrap this wire through the RF filter twice before snapping the RF filter closed around the wire.
SOURCE: i need the manual for the cobra esd 767
Go to www.cobra.com select U.S. then support then radar detectors and your model is the first one. Right now downloads are "off line" their doing updates to their system. but they say it will be back up soon. Hope this helps
SOURCE: I need a manual for
You can get the manual on the link below.
https://cobra.com/downloads/manuals/9200_MANUAL.pdf
Good Luck
