Question about Brother HL 5250DN Laser Printer
My printer refuses to acknowledge the existence of paper in the MP tray. HELP! FOR THE LOVE OF GOD, YOU HAVE TO HELP ME!
  • 1 more comment
  • BWildered Jan 09, 2009
    Same problem here.  Status light is red, paper light flashes yellow.  Paper tray is half full.  Will not print.
  • rockhound758 Jan 27, 2009
    Yooper, I have the same problem as the folks above, but it's a hardware/tray issue I believe, NOT a software issue (at least in my case). The little spring/wire that provides lift for the paper tray ramp is not working, and as a result the paper is not being lifted and the printer reads as out of paper. My guess is that the posters above are having the same problem. Any suggestions?
    Thanks in advance!
    Larry
  • marycla32 Feb 09, 2009
    I also have the same problem : There are still papers inside but it says there is no paper. It Jams sometimes too
    Jules
There may be a paper jam! If you have checked everything else, open the back of the printer and press the two levers which further release the back of the printer. You may find paper there. I spent nearly an hour conversing with a Brother technical expert because the paper light was blinking, the status light was red, though the computer indicated that the printer was ready, and the blue paper lever at the front of the printer tray indicated full on an empty tray. Once I discovered the paper jammed in the back of the printer and removed it, everything was great!
carterwilli
Posted on Feb 02, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
How do I clear a scanner jam for a MFC 8480
Hi Judy,
Please follow the steps posted below:
1. Remove the paper from the MP tray
2. Remove any jammed paper from in and
around the MP tray
3. Close the MP tray. Then open the front
cover and close it to reset the machine.
4. Open the MP tray again
5. Fan the paper stack, and then put it back
in the MP tray
6. When loading paper in the MP tray,
make sure that the paper stays under
the maximum paper height guides on
both sides of the tray
Let me know if this resolves the issue,
Thanks,
Hunter Quinn
IBM Help Desk
Dec 04, 2014 | Brother MFC Office Equipment & Supplies
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother HL-4040CN Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
I have an lexmark 630 and keep getting the error "load MP feeder plain paper" thanks for the help chip loye chapelthrill@gmail.com charlesloye@gmail.com
Please follow my tips ,When you print your computer before you go to print properties.Setting paper layout choice paper source and enable MP tray then print ok.
keep your mind before print you must be insert paper in MP tray.
Sep 28, 2009 | Lexmark T630 Laser Printer
MP Tray Paper Empty
"MP" tray is refering to the top fold down tray on the front of printer (bypass tray) You might load paper in the bypass and see what it does?
Aug 18, 2009 | Samsung CLP-610ND + Demo Laser Printer
Can this printer automatically choose the paper tray i.e. if the MP tray is open will it choose that instead of the cassette?
MP tray needs to be set on FIRST*
When paper is in MP tray, thats where the printer will automatically take it from. When there is no paper in the MP tray, or it is closed, the printer will take from the cassette.
Apr 09, 2009 | HP LaserJet 4 plus Printer
CLP-500N Paper Tray error
It wants you to put paper in the multi-purpose or pull down tray 1 assembly.
Jan 05, 2009 | Samsung CLP-500N Laser Printer
Brother HL 5250DN Laser Printer Logo
145 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
