Question about Goodman GMS90703BXA Heater
Heater fuse blows when ac is turned on
I replace the fuse on the heater and it will work just fine, yet when I turn on the AC, the AC works just fine, yet the inside breaker gets hot and I can smell something burning inside the house, then when I turn the heater back on, I find that it does not work, as this same fuse keeps blowing...
    Habit-Forming:
  • 16 Answers
Poor Wire connection on the breaker? Is the wire screwed down tight? SHUT THE MAIN OFF FOR SAFETY, then pull the breaker off the buss bar and inspect the bussbar and bottom of breaker for any burn.
It’s helpful to also use and ampmeter to check equipment amp draw vs. the amp rating on the equipment tag.
Posted on Jan 27, 2018
SOURCE:
  • 5 Answers
SOURCE: 3amp fuse keeps burning out
That fuse should be a 3 amp fuse. There is either a problem in your wiring, your A/C contactor or the board.
Posted on Nov 19, 2008
  • 230 Answers
SOURCE: The Exterior Units does not turn on.
It sounds like the outdoor unit is tripping on high pressure. This can be caused be a dirty outdoor coil. It can take hours for the unit to reset and try again. a loose or damaged control wire can also cause intermittent power loss as you have described. With that said I suggest that you call a technician to check it out.
Posted on Jun 17, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman a/c works, heater will work fine then fan will stop
you have a circuit board acting up. Try keeping the fan in the "On" position. It will keep the blower on all the time but it may work. There is a built-in delay not allowing the unit to come on after you reset it with the thermostat, wait three minutes or so to see if it comes back on. I still suspect a bad circuit board.
Posted on Nov 21, 2008
  • 252 Answers
SOURCE: my fridgidaire gas furnace is blowing cold air
Today’s furnaces are controlled by a computer which constantly monitors for problems. When it detects a problem it will shut off the burners. Depending on the problem and the specific furnace it will either “lock out” the furnace or cycle it through a purge (to rid it of un-burned gas and excess heat) and then attempt to re-start it. If the problem continues to occur then it will “lock out”. Depending on the problem and the furnace it may again attempt a re-start after several hours. In any case if the problem was not detected/caused by a sensor which requires a manual re-set, when the power to the computer is interrupted or the call for heat is interrupted the computer is reset and it will again attempt to re-start the furnace. The most common problems are:
· Low or lack of flame sense. Different furnaces use different methods to detect a flame – often these “flame sensors” become dirty and have to be cleaned (usually with sandpaper or steel wool).
· Bad igniter. (Doesn’t light at all).
· Clogged combustion air intake or exhaust.
· Clogged condensate drain. (90+% efficient furnaces).
This is not a complete list, only the most common!
Depending on where you live your HVAC system runs more than anything else you own (including your car). All furnace manufacturers “recommend” “regular maintenance” of your furnace. In fact, all that I am aware of state in their warranty that the warranty may be voided due to lack of “regular maintenance.” The industry has defined “regular maintenance” as yearly (in fact, some manufacturer’s warranties state yearly). Due to safety, liability, and the need for many other things to be checked, cleaned, and/or adjusted (2-page checklist where I work) to ensure safety and efficiency. Due to the large number of furnaces and the differences between them. Moreover, due to the terms of this site, I WILL NOT AND CAN NOT give you specific instructions on how to perform repairs on your furnace. I suggest that you contact a local, reputable, HVAC service company for (a tune up, preventive maintenance, general maintenance, yearly service call, general service, or whatever they call it).
While I may not have told you how to fix your furnace yourself, I have told you how to fix it. Please rate my answer.
Posted on Mar 14, 2009
SOURCE: Goodman GMS90703BXA Heater/AC - 3 Amps Fuse blows
It is a problem on your low voltage side. I had the same issue and found that my wire going to my outside condeser had been snagged on a wire hanger in my basement and was shorting out the system. I went a head and replaced the entire wire from my outside unit to my indoor and haven't had an issue since. So my advice is go to HD or Lowes and purchase some 14 gauge wire and replace the low voltage wire. If that doesn't work, then replace the thermistat wire, and thermistat. Great time to upgrate to a energy efficient thermastat.
Posted on Mar 18, 2009
Nissan Ac problems
vent flap shutting off?
Jan 14, 2018 | Cars & Trucks
AC isn't working
when a fuse keeps blowing it can only be one of two causes. either the consumer is loading the circuit too much due to a bearing problem or rusty component, or there could be a short circuit to ground. disconnect the blower motor plug connector and turn your a/c on like normal. if it blows the fuse again, replace the blower fan motor. if not, start checking the wiring for any exposed copper that might touch the ground-negative.also inspect all the plug connectors for water damage and corrosion.
Jul 08, 2013 | 1997 Toyota Avalon
I have a 97 Toyota Camry. The AC has been working great and gets really cold. Yesterday as I am driving the light on the ac power button starts to blink, after about 45 seconds the ac turns off and stops...
CHECK THE AC AND HEATER CONTROL FUSE.MORE LIKELY FUSE BLOWED BECAUSE AC COMPRESSOR COULD HAVE FAILED IF LOW SIDE IS OVER 100 PSI. THE REED VALVE PLATE IN COMPRESSOR PROBABLY DAMAGED CAUSED COMPRESSOR FAILURE BLOWED THE HVAC CONTROLS FUSE. HAVE AC SHOP CHECK IT OUT.
Aug 29, 2011 | Toyota Camry Cars & Trucks
The heater blows hot air when in cool position on a 98 olds bravada
AC not working?
on a hot day it will blow warm/hot air if the AC is turned off or not working
If its hot air and AC is working then i would start by checking the fuse or relay. if its not the fuse/relay then i would look into the heater box there is a door that blocks the hot air
Jul 14, 2011 | 1998 Oldsmobile Bravada
THE AC WONT BLOW OR THE HEATER
CHECK BLOWER MOTOR FUSE AND RELAY.IF BOTH GOOD.REMOVE BLOWER MOTOR HOTWIRE IT.IF DONT WORK REPLACE BLOWER MOTOR.IF BLOWER MOTOR WORKS.HEATER AND AC CONTROL SWITCH IS BAD.
Apr 30, 2010 | 2005 Chevrolet TrailBlazer
1998 Isuzu Rodeo is having issues.
check to see if AC and HEATER blower motor is getting power .if yes replace blower motor.if no you have problems in relay- fuse- or ac and heater switch is bad.for sun roof check for power at switch if yes sun roof eletric motor need replace.or sun roof in a bind.if no power to sun roof switch.blowed fuses and bulbs or turn signal switch is bad.
Jun 21, 2009 | 1998 Isuzu Rodeo
My AC was running fine before winter, now it only blows air.
If the system is working properly and you are only getting warm air, there are 2 common causes.
1.Check the air mix door motor and wiring.
2. There could be a leak in the AC system. No refrigerant means no air conditioning.
May 21, 2009 | 2004 Honda CR-V
2004 gmc sierra 5.3. AC not working AC Compressor fuse blowing
UNPLUG THE A/C CONNETOR ON THE A/C COMMPRESOR. REPLACE THE FUSE AND TURN ON THE SWITCH. FUSE OK . REPLACE THE COMMPRESSOR AND THE RECIVER DRIER.
Apr 17, 2009 | 2004 GMC Sierra
Heater
Try spinning the knob real fast in either direction. Sounds stupid but it worked for me.
Sep 27, 2008 | 2005 Chevrolet Malibu
Ac don't work
check a/c compressor by pulling compressor relay and jumping relay switch if cluch engadges you have a short if not
replace compressor.
Jul 20, 2008 | 2000 Mercury Grand Marquis
Goodman GMS90703BXA Heater Logo
57 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
