Question about Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive
External hard drive blue light is not working
My external hard drive blue light is not on
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
The 320GB does not seem to connect with my laptop. The blue circular lights come on just briefly when the power is turned on but then are replaced by a single red light that also goes out soon thereafter....
Looks like the power of your external drive is not functioning very well. Mostly with this kind of issues, it needs a port replacement or the external drive cable, and if it still does not work, then a complete external drive replacement maybe needed.
Jul 18, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
My WD external hard drive stopped working
wd external hard drive making ticking noise and seem to have lost all my photos and music
Dec 17, 2009 | Western Digital Computers & Internet
Blue light powers on but it's not recognized by my mac.
Your external casing might have some problem.Replace it with the new one.I think your hard disk is ok.
Jun 23, 2009 | Western Digital Caviar SE 120 GB Hard...
Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Jun 01, 2009 | Western Digital My Book Essential 1TB...
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
Verbatim usb 160 external hard drive.
That model doesn't have an external power supply port.
May 26, 2008 | Verbatim 160GB USB FireLite: The "drive...
Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
298 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
