Question about Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive
My elements external hard drive blue light is not working
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
My 500GB Elements external hard drive is not being recognized by my computer
check usb cable first might try another cable to be certain it's not communications
and afterwards, you might consider running this utility to optimize your ext drive
Jun 16, 2012 | Computers & Internet
Hard Drive elements by WD is not recognized
hi Stefan,
i suggest to run the check command
in run type cmd then you will see black screen type this command chkdsk x: /f /r x is the dirve alphbet.
even that does not work try this http://www.roadkil.net/listing.php/C1/Data%20Recovery
Jun 15, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
I purchased 2 WD elements 1TB. I have pluged it
right click on the drive , format it and it should work, if this not solves your problem go to the shop and use your warranty, it may be broken.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
When i plug the hard drive in, a blue light flashes but the dard drive doesn't turn on.
First check your usb port of computer and usb csable are working fine.
Then go to my computer proeprty then hardware then device manager then uninstall all usb drivers then restart the computer then check
Aug 20, 2009 | Western Digital Elements powered by WD 320...
My WD Elements 640GB Wont turn on.
I had the same problem. I fixed this by leaving the power supply connected with the wall socket for about 15 minutes, without connecting it to the external hdd. After that I connected the power supply with the external hdd and it worked perfectly. I hope this helps for you too!
Aug 02, 2009 | Western Digital Elements powered by WD 320...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
Broken Western Digital Elements 320gb external hard drive
hello,
there is nothing to do. you should brought new one. there is no other way.
thanks
ramesh
Nov 14, 2008 | Western Digital Elements powered by WD 320...
Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
102 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
