Question about Honeywell Programmable Thermostat Heater
Broken House Thermostat
My house thermostat was set by the previous house owners on a timer and now when I actually need warmth and try to turn it up it stays on 70 for about 5 minutes and then resets down to its timed setting. Is there a way to reset it permanently?
  • 61 Answers
You can hit the HOLD button to hold the temp indefinitely.
Posted on Jan 09, 2009
I have a Masport free-standing Vienna gas heater. Am able to light the pilot, but can't turn on heater. It is linked to an external thermostat. Would this stop the heater being turned on. C
If your external thermostat is set lower than the temperature in your house the heater will not come on. Make sure your thermostat is set higher than the room temperature and the heater should work. You can do this as an experiment just to try the heater for starting up. Then set it to the temperature you want for comfort. Do not disconnect the thermostat unless it is broken. Your thermostat maintanes the comfortable heat in your house.
Nov 03, 2014 | Heating & Cooling
Temperature control
Try this simple test
Turn the thermostat down to room temperature
If it turns off when you reach room temperature it means the thermostat is ok
Now if you place the thermostat back to 82 as you say you must have to leave it there until the warmth returns to the furnace thermostat
So it's either bloody cold were you are or your furnace is undersized
Dec 26, 2013 | Kitchen Ranges
We've just moved into a house with a Goldstar air
Check the thermostat, maybe the programming needs to be changed.
Aug 20, 2013 | Heating & Cooling
We have a new a/c and the system has heat strips. For a/c. we have had the thermostat set on AC at 72degrees. Now that it is getting colder and may need some heat in the house, do we switch the...
If your thermostat has an emergency heat setting this means you have a heat pump system.
Yes you need to set the thermostat to heat for heating the house.
The emergency heat setting should never be used unless your outside unit is not functioning.
The emergency heat setting overides the heat pump (the outside unit will not be energized).
The emergency heat setting will run the auxillary heat (heat strips) only.
When the thermostat is set in the heat position the heat pump will run to heat your house.
If the heat pump can't keep up (extreme cold) then then the auxillary heat will kick in to augment the heat pump until it satisfies the thermostat settings. If your room temperature gets 2 degrees below your thermostat setpoint, your auxillary heat will kick on. Example, say you are going to be gone a couple of days and you turn your heat down to 60 degrees. When you return and it is 60 degrees in your house, you turn the thermostat up to 70 degrees. Since you are turning the temperature up 2 degrees or more (10 degrees in this case) from the 60 degree room temperature then the heat pump will come on and the auxillary heat strips. The unit will continue heating like this until the temperature in the house gets to 69 degrees and the heat strips will turn off and the heat pump will continue to run until the 70 degree setpoint is reached.
Hope this helps.
SeagullAC
Sep 15, 2011 | Heating & Cooling
AC comes on and stays on until you move the setting up to around 90. At times the unit will not cut off no matter what setting you choose. If it cuts off at 90 after manually moving it there, you only have...
If the house is actually cooling, but the thermostat thinks in 90 degrees in there, you definitely need a new thermostat. If the house is actually 90 degrees, the AC SHOULD cycle on and stay on till it reaches the preset temperature. Since it doesn't make sense that you would complain about the AC cycling on at 90 degrees, I can only conclude that you have a faulty thermostat.
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
How do you reduce an electric bill in a all electric house?
The biggest wasters of electrical energy are Heat and A/c, water heaters,dryers and ranges. The more you insulate the less you have to cool or heat. If you live in a warm climate, consider installing an attic fan that runs on a thermostat or timer. During the summer allow it to run, during winter turn it off. Ceiling fans in rooms that are occupied create the illusion of being cooler, allowing the thermostat to be turned up.I'm not sure of the exact numbers but any thermostat setting on your a/c below 78 is more inefficient so try kicking the a/c up and the heat down. I'm a Florida boy so I can't tell you much about baseboard heaters. I know that anything that heats things up cost a lot in energy.
Consider installing a hot water heater timer. Commonly called a "Little Grey Box". Whenever your water heater is not actually being used it is still heating the water. A big waster. Once installed set the timer to cycle the water heater off during times when you commonly don't use it. Overnight,when your at work etc....
Somewhat antiquated, but a clothesline always uses 100% less energy than a clothes dryer. :) Short of this, try to fill the dryer all the way and make sure your dryer vent and lint trap are clear.
Microwaves draw 1/3 the energy of a range and run for 1/10 of the time. Microwave as many things as you can. In our house we have started microwaving canned veggies and boxed side dishes and such.
These are the big ones I've done at my house. A lot of the other things seemed to be more work than they are worth. Some actually end up costing you more if you don't own the house for decades.
There are many sites you can visit such as your local power company and possibly your local government pages.
Good luck. I'm in the same boat with the high power bill.
Mar 24, 2009 | Fahrenheat F2543 Baseboard Heater
How to use the digital thermostat (honeywell)
what type of thermostat is it, find out the model and or the make and i"ll be able to walk you thru
Dec 21, 2008 | York Yankees Bedding MLB Comforter
Heating & Cooling Logo
186 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
