Question about Bernina Artista 180
HAVE LAPTOP AND BERNINA 185 EMBROIDERY SET UP HOW CAN I MAKE CORRECT CONNECTIONS WITH USB PORTS, ETC.
  • 3 more comments
  • Anonymous Jan 11, 2009
    NOT QUITE. HAVE AN ADAPTER AND STILL CANNOT SEND DESIGNS TO SEWING MACHINE. IT SAYS "SERIAL PORT ENGAGED"
  • Anonymous Jan 28, 2009
    I am trying to connect my 185 with the serial to usb and still can not send of receive designs from the sewing machine.
  • bettyjun49 Feb 08, 2009
    Actually, my machine is a 180, but "no link to serial port" is the message I keep getting. And I already have a Radio Shack serial/usb cable. I've been fighting this for, literally, weeks... Thanks for any help.
  • sisco-willia Feb 11, 2009
    I have had the same problem and was instructed that a belkin usb cable is the only cable that has the correct interface to communicate between the computer and the Bernina 180 sewing machine.
  • cybereilw Feb 24, 2009
    Same problem - new laptop with no serial port.  I have gotten a serial to usb, but when I try to send a design to the machine (180), I keep getting the message, "no serial port connection."  The software was set on Com Port 1, so I tried the others, 2-4, but the same thing happened.  Is there a specific brand/type of serial-usb cable that must be used?  Please let me know.
You must purchase a Serial (port) to USB (port) adapter. I got mine at Radio Shack. Hope this helps
Posted on Jan 11, 2009
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
I have a Bernina 180 with embroidery module. If I upgrade to a Bernina 640, would it work with my 180 module?
Unfortunately no, I think that the 185 and beyond use the same emb module. The 180 if I remember correctly, has the memory and card reader in the module itself and may have a different plug. I do know for sure that the 180 hoops will definitely not fit on the newer modules. Sorry to disapoint, Allen
Feb 03, 2011 | Bernina Artista 180
USB to Serial port cable for Bernina Artista 180
Just happen to be sitting in front a Bernina 180 at this very moment - with the connecting cable attached to a Keyspan USA-19HS Adapter. It is a current adapter available from either Keyspan (www.keyspan.com) or any number of computer retailers - physical or online. Seems to run around $30.00 just about everywhere. Auction sites may have bargain. Worked like a charm on an older XP computer as I was able to test the older software I had due to it having the necessary parallel port the the older dongle. While I am fairly certain this combination would also work on my Windows 7 computer, I am unable to test it as I have not come across a parallel adapter that will work with the older software parallel dongle. I've had other programs/peripherals that utilize usb to serial adapter (on my Windows 7) that have worked fine, so I suspect this would also be the case.
Hope this helps. If you have specific questions, please don't hesitate to contact us.
Happy stitching,
Kim
www.sewingexpressions.com
Jun 23, 2010 | Bernina Artista 180
I need to order one I lost mine bernina 180 cable
This is for connecting the embroidery machine to the PC?
You will need a cable with USB port A on one end and USB port B on the other - both male.
You can get this style of cable at an electronics store.
If this is not what you mean, then you need a Bernina dealer to order one for you.
Feb 20, 2010 | Bernina Artista 180
I am looking to buy an embroidery module for a Bernina 185
Are you still looking for embroidery module?
May 18, 2009 | Bernina Artista 180
Bernina 185 and laptop - device not detected in activesync
Go into the control panel and find what Com port the usb adapter is using. Change the com port to match in the software.
Feb 22, 2009 | Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Can't connect my Bernina 170 Embroidery unit to my computer
I just bought a new laptop and upgraded to V.6. Since I have always used a magic box I didn't know how to attach my bernina 170 directly to the laptop. My bernina dealer said that I would first need a serial to usb adapter since my machine is old enough that it doesn't have a usb port on it. Make sure it doesn't have the screws on the serial part because they will not allow you to attach it to the machine. He also said that I may have to make a new com port as most pc laptops only show 4. I did a search of the computer and found how to make a new com port. A little more fiddleing around with the laptop and cables and restarting both then it somehow recognized that I had made a new com port. Voila. It now works. (I am a Mac person). Hope this helps. margaret
Jan 04, 2008 | Bernina Artista 170
Sewing Machines Logo
445 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
