Question about Acer Aspire 3000 Notebook
Need to keep pressing F1 in order to boot up
This has been going on for a while now. i have to press F1 to boot up my notebook or else it wont work. and another thing is that i cannot shut down or the next time i on it, it will get stuck at loading windows... so, i always put my com on stand by i have reformat it but it stays the same. Any advice will b greatly appreciated. d(^_^)b
  • Nisa Jaafar Jun 02, 2007
    the clock is working fine, there was'nt any need to change it.
    thanx anyway sandrew!!
    juz another qns though, do anyone noes how i can get my wireless network to work again without having to plug in an external device?
    President:
  • 2,961 Answers
If you have to press F1 to enable the bios to pass without a system check, keep an eye on your time clock as it will probably be wrong or need to be corrected every time you boot up, if this is the case then your CR2032 cmos disc flat shaped battery that is located on the motherboard needs replacing
Posted on May 30, 2007
Presario v2000 wont boot it powers on then screen says press F1 or F10 but can go no farhter
Sounds like it is not seeing a bootable device, maybe bad hard drive, could be a bad setting in bios. Click here for tech support
Mar 26, 2013 | HP Compaq Presario V2000 Notebook
My lenovo thinkcentre desktop computer never shows "press any key" while I try to format. Unable format my C drive and recently 500 GB HDD was installed in my computer. pl.advise how to format...
Hi! Welcome to www.fixya.com.
Removed your power cable and drain power without any power. restart and keep on hitting f12 to get to the boot menu choose ODD then put the OS CD then press enter until its say press any key. If it did not work your other option is reboot and hit f1 or f2 to change the boot sequence on boot option. Restart pc then hit f2 go to boot option and choose DVD/CD to be your first boot option then press f10 restart and it should load automatically.
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Jul 20, 2011 | Computers & Internet
I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
Presario v2000
Try this; Press Fn+F1 instead of F1 alone or Fn+\F2 not only F2. Most laptops are by default Fn key activated so we always need to press it with the key combination.
If this doesn't help, there must be internal faulty/problem. Boot up the system and keep pressing F8 and go into "Advanced Boot options", if it's working, then there's no hardware, must be the Fn key.
Good luck
Thanks for using FixYa.
Jul 03, 2010 | Computers & Internet
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Cannot enter bios boot order
just when turn on notebook press esc then appear option f1 and thats all
May 10, 2009 | Toshiba Satellite U205-S5002 Notebook
My laptop wont boot
press f1 and watch what happens..should be ok
Apr 27, 2008 | Getac C71A1A00GA00 Notebook
Hp 9695c wont boot only ht HP banner shows but wont go to the initialization
Press and hold down Shift key, when you hear the beep, until system boots.
If you dont time it right you will get a keyboard error, dont worry, just press F1 key and immediately hold your Shift key again.
Your system should boot into basic mode, then you need to check your system for virus or last software that may have been installed.
Nov 25, 2007 | HP Pavilion dv9000z Notebook
Press (F1) to resume, (F10) to setup
I need a bit more info to try to give you an accurate solution
Does the screen change after you press "F1" ?
Do you have access to an external keyboard, if so try plugging that in while the computer is off and then using that to press "F1"
Nov 15, 2007 | Compaq Presario M2000 Notebook
Acer Aspire 3000 Notebook Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
