Question about Adler Royal HT500X Shredder
Royal ht 500 x shredder
When trying to shread 1 piece of paper it stops about one qtr thru the
page this just started and it has worked till now, when moving switch
to reverse the machine continues to run. The machine is about 1 yr
old and do not have the instruction book any more. Can you help
When I recieved your reply to check the micro switch I found the contacts had built up a little
arcing on the points, I then filed the points and cleaned them with alcohol and put it back together
It works like new. If it bothers again i may try to get a new switch for it I owe you a large thanks
for the info to fix my problem
Sincerly Joe Gese
Posted on Jan 08, 2009
My shreeder starts fine then slows down like a motor till it stops just before the page is done. It does 2 pages then won't work.
Posted on Dec 14, 2009
When trying to use the 160MX crosscut paper shredder, when you insert a piece of paper it starts to go in then stops. If you hit reverse the paper comes back and the edge is cut up. The motor sounds...
Try putting some "shredder" oil onto the cutting blades...they should be lubricated routinely and if they have never been oiled they just may be plugged up with paper dust and debris.
Feb 23, 2011 | Royal 160MX Shredder
I have a Royal CX 66 Crosscut shredder and attempted to shred 10 pages. The unit shredded 1/2 of the papers and the other 1/2 are stuck in the shredder; the reverse mode will not release the papers. Is...
The Royal cx-6 shredder is a small consumer shredder rated for "up to 6 sheets at a time" so yes it will jam with anything more that 6.
If running it in reverse won't work you will have to try to open it up and see if you can manually turn things to get the paper back out...there is no other way if it wont run in reverse...hopefully when you have the paper removed the machine will still function.
Oct 27, 2010 | Royal CX6 CrossCut Shredder
My royal ag10x cross cut shredder is losing steam - labors thru 4 pages at a time and i've never done any maintence in 8 years. is there a way to sharpen the blades?
May not be the blades that need sharpening.....try putting some lightweight shredder oil on a sheet of paper then shred the sheet of paper....do this 2 or three times and see if it helps. It won't hurt to put a good bit of oil on the paper.
Aug 30, 2010 | Royal Office Equipment & Supplies
At a point, when the paper is being feed it, there is a knock and top of shredder is lifted as the the shredding gears try to revolve, then mechanism stops and reverses the gears and stops.
Try holding a piece of paper in the "eyes" to see if the machine runs forward...if it won't then it sounds like something may be broken inside...it will have to be opened up to see if anything obvious is damaged. If you need parts then call Royal at 1-800-524-0799.
Aug 12, 2010 | Royal Office Equipment & Supplies
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
CD shredder jammed with small CD pieces
If you are able to remove the top. It is easy. Usually 4 screw to remove the top. Be careful with the short cable connecting to the board. Open it up pressure clean the entire unt and especially the sensors top and bottom.
Jun 10, 2009 | Royal 160MX Shredder
Ht500 shredder
check the cutter slot, there should have a micro switch with a level, that detect the paper when the paper is in the slot.
the micro switch may be dirty or some thing is preventing it from starting.
Jan 07, 2009 | Adler Royal HT500X Shredder
Adler Royal HT500X Shredder Logo
475 people viewed this question
Top Adler Royal Office Equipment & Supplies Experts
Electroboy
Electroboy
Kevin Michael
Kevin Michael
Are you an Adler Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
