Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer fills up but wont spin
I have a whirlpool washer modle #lsw9245eqo the machine fills water but wont go to the cycle. after the water fills up then it makes a humming noise like the motor is stuck I check the bushing between the motor and its fine i wounder if its the motor or the relay on the side of it please give me some advice on how to repair this also give me some advice on how to check the pump the motor and the relay thanks howard
  • 1 more comment
  • dyerdigs Jan 08, 2009
    MY whirlpool is also filling up and then stopping. Someone suggested to tighten the screws on the lid switch and the hole that the little L shaped switch pushes into when you put your lid down. I happened to turn the darn screw the wrong way by accident and the nut fell from behind the screw immediately and is probably lost at the bottom of my washer. Ahhhhh! I will just have to watch it and hope I can either recover the nut and remove the top cover of the basin so I can put on a new nut. Now I have two problems, only one nut and possibly still the first problem.
  • happilywande Jan 09, 2009
    I am having the same problem with the spin switch. Both nuts are loose and if I couild figure out how to get the lid up, I could solve it easily. Can you tell me how to get the lid up.
    Thank you.
  • Anonymous Mar 20, 2014
    water fills , but motor won't start
    Problem Solver:
  • 15 Answers
Heck your lid switch make sure it isnt broke and if it isnt you will need to replace the motor and pump coupler it comes with three pieces 2 nylon busshing and a rubber gromet that connects the 2 nylon pieces together very in expensive (usually under 20 bucks) you can easily purchase one at your local dealer or anywhere on line. Glad to be of service
Posted on Jan 08, 2009
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Whirlpool washer LSQ9549LN0 problem
    you have a problem in the transmission of the washer
    May 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    191 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
