Question about Nakamichi CD-400 CD Player
Clock My manual is missing and I can't remember how to reset the clock. I have been trying since Daylight Savings.
1.While the unit is off, keep the CLOCK button depressed  and press HOUR adjustment button to set hours.
2. Repeat with MINUTE button.
Also, you can get a manual for the unit from Nakamishi. They will want the serial number of your unit.
I hope this helps.
Toothman 1
Posted on Nov 20, 2007
The time show late every single day..every day i must turn the right time..
Do you have your DVR set for automatic clock updates? I changed mine to manual clock settings because of problems with the new dates for Daylight Savings Time. Every few months I have to adjust the time by a minute or so if I find I am missing the intro to programs that I record. I also have to do the Daylight Savings Time shifts each fall and spring.
Nov 21, 2009 | Panasonic DMR-E55 DVD Recorder
My clock went back one hour on Sunday 10/25, need to get it to move ahead one hour.
The clock program for Daylight savings Time is programmed for the old "third Sunday in October" changeover. The new changeover is the first Sunday in November. The program probably cannot be updated. If there is no button or setting to disable automatic change to Daylight Savings Time you can set the time manually and then change it manually to Daylight Savings on November 1 for the time to be correct.
Oct 26, 2009 | Emerson Smartset Clock Radio
Can't change clock to eastern standard time
Can't solve it but the clock doesn't know the government changed when daylight ends.
Nov 04, 2008 | RCA RP5430 Clock Radio
Change time zone
To change the time zone press and hold the time zone button until the number after the Z in the display flases and then release the button (number will still be flashing) and then press the same buttoon and you will see the Z number change to the zone you need. The zones are printed on the top of the clock under the top lid that pops up. My problem is we are in daylight savings time and I cannot get the Eastern Time zone to let me "spring ahead one hour" for daylight saving time!
Nov 02, 2008 | Timex T276B Clock Radio
Wrong Time
This appears to be a issue with the Magellan code. The Magellan code is setting Daylight Savings Time according to 2007 rules and not the 2008 rules. Magellan support indicates to change the time zone from Eastern to Central, save it and then put the time zone back to Eastern Time. I do not understand this solution. You can simply uncheck the Daylight Savings Time option and this will put the clock to the correct time. You will need to check the Daylight Savings Time option to put the clock ahead one hour when the clock is off by one hour. Magellan support informs me this is a manual process. Magellan needs to create a fix in their firmware to change the clock according to 2008 Daylight Savings Time when the box is checked.
Oct 23, 2008 | GPS
Emerson Research SmartSet Clock Radio
There is a solution for this already. You can reprogram the clock to use the new DST settings.
See http://www.fixya.com/support/t137304-daylight_saving_time_issues
Mar 10, 2008 | Emerson SmartSet CKS1850 Clock Radio
Daylight Savings Times Changed
We set the time zone to '7' , which is Hawaii time zone where there is no change for daylight savings. This came up because it changed automatically on this morning...and although we can change it back, then it won't change next week when it should. So we're hoping that by setting it to Hawaii it will be a regular clock, we will do the changing...but at least we won't be surprized as we were this AM.
lb
Mar 09, 2008 | Emerson SmartSet CKS1850 Clock Radio
Help daylight savings time is not here yet
I am going to try changing to time zone 7 (Hawaiian Time). Hawaii does not observe DST so this should turn the clock into a regular clock that ignores DST and you need to set yourself twice a year.
Oct 30, 2007 | Emerson SmartSet CKS1850 Clock Radio
Turning daylight saving time OFF
If DST is *already* set to "on" when you reset the time zone to Z-07 (Hawaii), my very recent experience is that the time *still gets adjusted back* by one hour.  Now that daylight savings time is over (at least according to the clock's pre-programmed and outdated schedule) I'm hoping that setting the time zone to Z-07 (Hawaii) will completely cancel the automatic time changes from now on.  Otherwise, I need to purchase another clock, and it won't be a Timex.
Apr 02, 2007 | Timex T311T Clock Radio
Open Questions:
Naka CD-400 output voltage inbalance problem Hi , i'm having some problem with my cd400 HU and i would really appreciate it is someone could verify this. The problem : The output line level is not balanced.ie the left and right has a very big output voltage differece and being such an CES award winning product i'm sure this is not design flaw rather an isolated case. Being a tech myself , i did my own the measurement of all the output line level voltages. Let me list down the voltages measured from all three pre-outs. Right Ch Left Ch Front 2.9/3.0V 2.2V Rear 3.0V 2.9V Sub 2.6V 2.5V I did all these reading off a true RMS DMM with volume at 60 ( max ) playing a 60Hz, -3db sinewave test tone. Though the variations are small, but , at the speaker's end from the amp it depicts quite a large difference in output voltage between the right and left channel . - ( Front ch ) Rite now i'm using the rear pre-out since it seems to be much stable and puts out nearlly the same amount of output voltage on its left and right channels. Is the differences audible with the front ? yes cause the volume was focused a little more on the right speakers. That was the point i started checkin all the components in the sytem and i must say i never suspected the HU as the culprit given its a high quality naka product. I've approched my dealer on this but according to them its normal, but i just cant agree with this since my stock HU gives out a more consistent level. I hope someone can shine some light on this issue. Thanks guys the reply would trully be appreciated.
Feb 27, 2017 | Nakamichi CD-400 CD Player
Nakamichi CD-400 CD Player Logo
211 people viewed this question
Top Nakamichi Car Audio & Video Experts
Mohamed Ismail
Mohamed Ismail
Jaime Hernandez
xxxxxx xxx
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
