Question about Logitech Z-640 Computer Speakers
I have a logitech z-640 5.1 sirround sytem and i want to connect it to a soundblaster creative audigy 2 card and need a diagram of proper connections
2 Suggested Answers
tricked out
  • 46 Answers
SOURCE: X-540 Speakers
go into sound device on control panel. make sure digital is unchecked.
Posted on Feb 14, 2008
SOURCE: logitech x530
I have had this a few times with customers. You might want to check if the sound cards front speaker ports are working correctly. If the card is working, the problem might be with your right front speaker, ckech that it is working. You might also want to check the settings in control panel; this has helped me a number of times.
cheers
Posted on Nov 03, 2008
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
Nov 02, 2010 | Logitech X-530 Computer Speakers
Ive got creative inspire T7900 7.1 speaker system attached to my pc.one of the speaker connections in sub-woofer is faulty ? the sub-woofer seems to be a sealed unit so cant take panel off to have a look...
Is this connecting to a sound blaster audigy 2 zs or xfi soundcard? or a motherboard onboard soundcard/ aftermarket Other than creative?
If connected to the creative card odds are the wire is bad. get a new one
If connected to a generic the wires for the speakers are proprietary and you have to go get 3.5 to 3.5 stereo cables to hook it up
Sep 04, 2009 | Creative Labs Inspire T7900 Computer...
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Mar 26, 2009 | Logitech Z-640 Computer Speakers
Need a wiring diagram for connecting KOSS HD 50 COmputer speakers
Hello there! lellya
First,
1) you have to tell , what kind of sound card you got? on board audio? A7, or Creative Audigy? 5.1 or regular.
2) then, you have to connect one speaker to the other, one two way connector cable, for the 2 KOSS speakers.
3) another cable that goes in back of your koss and from the out of your KOSS Speakers to the input of your sound card, at back of your PC, this input is your sound card jack.
4) its supose to work like so.
good luck
Oct 16, 2008 | Koss HD 50 Computer Speakers
X-540 Speakers
Feb 08, 2008 | Logitech X-540 Computer Speakers
Connecting X-540 speakers
Green is the speaker out let.
Make sure the sound card is activated.
Dec 26, 2007 | Logitech X-540 Computer Speakers
Connecting computer speakers
HI SSSNAP
Happy Holidays
Well, you have to : depending on the model of your Sound Card, I presume SBlive? or Audigy models, refer to the manual, but, you have too, depending on the speakers model, place the cables according (ussualy) for the colors. green , black, orange on the respective places. test as you move the cables.
good Luck
Nov 20, 2007 | Logitech Z-5500 Computer Speakers
Logitech g51
I'm sure you went to Control Panel, opened device manager, and and checkeck for any yellow checks for your
sound, video and game controllers. If there are none, your system is go. Then go to your audio manager on control panel, and set it up for whatever speaker configuration you have. I have realtec audio manager. This step is a must for configuring—you choose whether your laptop will use its own speaks or use your external speakers—you have to turn off the internal speakers and turn on the external. Did you forget?
Nov 08, 2007 | Audio Players & Recorders
Logitech Z-640 Computer Speakers Logo
106 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
masterwest
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
