Question about Fujitsu Siemens LifeBook E8010 Notebook
My laptop screen needs a new ribbon
I've just brought a second hand laptop and found out that it needs a new ribbon for the screen and have no idea were to get one from it's for a fujitsu siemens life book e series
    Scholar:
  • 65 Answers
Hi there :)
After I did some research for you and for the part you mentioned I found that RogerHenson can be very helpful. You will be required to send him a detailed email with the laptop info (serial number, model number brand , year of manufacture etc). Tell him which part you require and he will be able to send it to you via courier within a short time :) Here is the email roger@rogerhenson.com he is very helpful for sourcing out hard to find laptop parts :)
It was nice helping you :) and hope you wll be up and running soon :)
Best Regards
Posted on Jan 07, 2009
Cda wc140in
Hello, hope you can help? I brought a second hand (but brand new, but not used CDA wc140. Its plumbed in fine, switch on, the end light comes on, the programme button just beeps when pressed. There's no info in the manual. I hope I haven't brought a second hand dud, any ideas to start would be greatly appreciated. Steve...
Apr 24, 2012 | Dishwashers
I need a harddrive ribbon cable for Getac A770. I have caddy.
Try e Bay, I've found several unique computer cables I needed there, including SATA & PATA cables that were too expensive locally.
I also used that same resource to stock up on extra cables for PC expansions & repairs. They take a while, but they are priced low.
I've experienced very few issues with products purchased new from overseas.
Mar 22, 2012 | Getac Computers & Internet
Cracked screen has caused a massive black blob across screen. Need to buy a new screen..
I am so sorry to hear that! I've had to deal with a broken screen or two before myself. What you'll need to do is search for your computer model's screen. They usually run about $100. After that, you can either contact a professional to do the work for you, or you can do it yourself.
To do it yourself, you will need a Philips and flathead screwdriver. BEFORE YOU DO ANYTHING, remove the battery and hold the power button down for 5 to 10 seconds. This will discharge any remaining power from the laptop, so you don't harm your computer. There should be four little pads in the corners of the screen case. Remove these, and unscrew the screws underneath. This is where you will need the flathead screwdriver. Gently pry the front of the case from the back. Once the case is opened, unscrew the housing of the LCD itself. There is a ribbon that connects the screen to the motherboard. Gently remove this. Now, just do everything in reverse, with the new screen. Put the ribbon in the new screen. Replace the housing and screw it back in. Then, replace the screen case and screw it back together. Put the little pads back on and replace the battery. Turn on your PC and marvel at your handy-work.
Hope all goes well! Thank you for using FixYa!
Jul 19, 2011 | Computers & Internet
Samsung ST550 Camera Touch Screen Unresponsive Had the camera for 18 months and over the last 3 months the left hand side of the touch screen has stopped working. The camera's lived in a protective...
I had this problem about my touch screen same with you. The touch screen on left hand has stopped working. I had it for 20 months. I live in Thailand. I think that it is the big problem for ST550. I've brought it to Samsung Customer Center. and they've introduced me to change the new touch screen. It is about USD50.00. I am bored. I used it a little bit.
Jul 16, 2011 | Samsung DualView TL225 / ST550 Digital...
LCD ACER LAPTOP. YOU CAN SEE ONLY WHITE SCREEN. LCD FOR REPLACEMENT. WHERE TO BUY CHEAP PARTS. TH
> only white screen
It may possibly be a loose connection of the ribbon-cable between the motherboard and the LCD.
Check both ends of that ribbon-cable, before spending $100 for a "pre-owned" screen, or $250 for a brand-new screen.
Inexpensive parts, if you really need them, can be found on eBay's web-site.
Jun 01, 2011 | Computers & Internet
Laptop lcd screen issues
There is a card you may have to replace, or replace the enire LCD Assembly
Jul 16, 2009 | Computers & Internet
GX-6750
The ribbon doesn't advance at all? Try turning the ribbon by hand. If it is really hard to turn, or doesn't advance when you turn the knob (make sure you turn it in the direction of the arrow), then the ribbon is defective and you just need to get a good one.
If the ribbon turns easily, the leave the ribbon off, type and watch to see if the black knob on the left of the ribbon plate (the place where you put the ribbon), that turns the ribbon, is moving.
Also I have found that some brands of ribbons simply do not work on this machine. If the ribbon and the ribbon drive is working, try a different brand of ribbon.
Oct 22, 2008 | Brother GX-6750 Typewriter
Lg chocolate
bought a lg kg800. supose to be unlock, but it not. need a unlock code.
Feb 09, 2008 | LG KG800 Cellular Phone
Replaced Bottom screen bypassed fuses still problems
the backlight or fuses are dead. Do not bypass fuses or you'll kill your system.
Jan 23, 2008 | Nintendo DS Lite Console
Fujitsu Siemens LifeBook E8010 Notebook Logo
353 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
