Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The liftmaster garage door opener issues
The door opener runs but doesnt move the door
  • John Houtz Aug 22, 2013
    New car. How do I get the car visor button and the door opener to talk to each other?
    An expert whose answer gotĀ voted for 100 times.
  • 98 Answers
If you have a Chraftsman/Liftmaster:
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
  1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of lubricant (not WD 40)
  2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken or needs more tension) in this case call a professional door repair company in your area.
2. If the door runs fine your gears might br out of your opreator. Open the case and look for a white powder. If you see that and your gaers look worn repace the gaers with 41c4220a gear kit.
Posted on Jan 09, 2009
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
Sears Parts D... Liftmaster 41C4220A Ge...
Preferred Do... Chamberlain/l... Sprocket, Gea...
eBay Direct Replacement f...
Moving Up G... Liftmaster 41c4220a gea...
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
M otor hums but door does not open
If the motor is running and the chain or belt isn't moving, you have a broken gear in the opener.
Mar 26, 2014 | Sears Craftsman LiftMaster Chamberlain...
Hi.. my 1/2 horse liftmaster garage door op[ening is having ANM issue the remote in the truck only opens the door doesnt close it anymore...when you click ticks repeatedly at the 1/2
Ensure that your electric eyes are aligned.
Disconnect the opener from the door and run the door down & up by hand. Does it move smoothly?
Most openers only require momentary contact to get them to open or close.
I have a doorbell button on mine in my house.
Aug 25, 2011 | liftmaster Chamberlain Garage Door Opener...
Have a Craftsman 1/2 HP Garage Door Opener, been working fine. Now when you start it you hear the motor running as normal but the chain doesnt move?
You must ensure the drive chain is engaged to the door puller.
Sometimes the emergency release if pulled (red cord) the drive and the coupling come separated.
Make sure the pin is back in place (pull release cord and make sure pin springs back in).
The run an open close cycle, it should pick up the drive again.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
Feb 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener: motor runs but chain doesnt move.
Depends on your mechanical ability. The drive gear is stripped. The part number is 41A2817 and is available at any door opener service company. It comes with instructions.
Jan 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Malfunction
Aug 26, 2009 | Liftmaster, Chamberlain, Sears Door...
Craftman door opener brand new wont work?
Sounds like the drive gear is stripped. Remove the cover and take a look. It is white nylon and is just in front of the motor.
Jul 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor runs, but the chain drive doesnt turn
If the chain is not moving and the motor is – you need a gear kit.
Unplug the unit - take of the cover – you will find white shavings inside – these confirm the diagnosis. .
Get the gear AND sprocket kit.
It’s a good DIY project but you MUST VERY CAREFULLY Follow the instructions step by step.
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor sounds like it is running but sprocket doesnt move
how old is unit. sounds like gears are shot, takes $25 of parts and 2-3 hours to fix if you are handy. Take cover off, If it has white powder (Not ****), gears are shot.
Jan 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Everything is moving but the door isn't opening
your gears are probablly shreaded. the good news is that your motor isnt dead. you will probabllly need new gears depending upon which ones were shreaded. seeing plastic shavings and or plastic pieces inside unit is an indication of that
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
281 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Are you a Sears Building Material Expert? Answer questions, earn points and help others
