It says to reboot and select proper boot device
The operating system is looking for the boot device make sure there are no disks in all drives cd , us and floppy if applicable Acer: - Ctrl+Alt+Esc This will set the boot order. The device drivers for the hardware are faulty or incompatible. There is a connection problem such as a bad cable for internal hard drives secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
Make sure the bios is set to to boot from your hard drive.
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
The hardware that you are trying to access is damaged or failing.
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
If you need more help with this post a reply
Hope this helps
